Go Back  RCU Forums > RC Airplanes > Aerodynamics
 DRAG.....Help please >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 09-18-2008 | 11:45 AM
Default DRAG.....Help please
How much drag is there on a 8inch sphere at 200mph also at 100mph at sea level in a wind tunnel ,,also a 10inch sphere ...same critiria.....thanx in advance...TROU
Old 09-19-2008 | 03:22 PM
CrateCruncher's Avatar
Default RE: DRAG.....Help please
The sphere will be in a Reynolds range of 620k to 1,550k which is well past separation. At 100mph the Cd is about 0.1 and climbs to 0.2 at 200mph. Therefore the drag force for the 8" sphere at 100 would be .88 lbf and at 200 would be 7.12 lbf. The 10" sphere at 100 would be 1.38 lbf and at 200 would be 11.12 lbf. You could drop the Cd substantially through streamlining. The sweet spot for streamlining is a thickness/chord ratio of 0.25...
Whats it for?
Old 09-19-2008 | 04:39 PM
THANG X for the reply C C i do value your input ....however what is lbf ?? please.......OR how much thrust requierd to push a 10inch / 8inch smooth ball at 100 and 200 mph at SL..
Old 09-19-2008 | 04:51 PM
Sorry, lbf is a force read "pounds force" to distinguish it from "pounds mass". Ye Olde English Units can be a bit confusing but at least we don't have shillings to deal with - Jefferson got the money right. Anyway, you would need an equal amount of thrust to propel the sphere at the given velocity and diameter.
Old 09-19-2008 | 05:11 PM
Thanx again CC im realy hopping for some hard numbers... since i dont have force thrust or drag.....
Old 09-19-2008 | 09:41 PM
Let me try this again. Drag force is the same as the thrust force needed to propel the sphere at the constant speeds you asked about. So, the numbers I gave you are the thrust required to push the sphere at that speed. An 8" sphere traveling at 200 mph requires 7.12 pounds of thrust to maintain that speed at sea level. Thrust force = Drag force. OK?
Old 09-19-2008 | 10:29 PM
Thangx mate presheat that.......just gut feeling no math at all i guest 25lbs ish for 8 inch spere at 200 mph
