Go Back  RCU Forums > RC Airplanes > Aerodynamics
Reflex Ailerons to Shorten Glide? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 06-04-2003 | 08:40 PM
Default Reflex Ailerons to Shorten Glide?
Does it make sense to raise the ailerons on a model to shorten the final approach? My one try at flaps created a scary, too-steep drop to the field.
Dave Segal
Old 06-05-2003 | 01:17 AM
You may find useful info in this thread:
http://www.rcuniverse.com/showthread...350&forumid=19
Did the plane pitch down when you dropped the ailerons?
The linked thread advises some elevator mixing. Essentially, the plane needs to be retrimmed when you drop the ailerons (flaperons), and the mixing accomplishes that.
I plan to test the theory soon myself..
Old 06-05-2003 | 02:31 AM
> Did the plane pitch down when you dropped the ailerons? <
It was some time ago and all I remember is that it was my jockey shorts that were dropping when I hit the switch! (G) But thank you for pointing out that thread as it has a lot of useful information.
Dave Segal
