Go Back  RCU Forums > RC Airplanes > Aerodynamics
Does dihedral really help? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 06-25-2003 | 03:21 PM
Default Does dihedral really help?
Every trainer I've ever flown does not have the tendency to right it self hands off. The reason I ask is, I'm going to build a trainer for my wife to learn to fly, and if at our level of flying(RC models), it does not help stability all that much, why have it. It makes inverted flight very difficult. Why not make a thick wing with low W/L, and an A/R of 5 or 6(like a big stick)? If, in fact, it does help stability, what is the optimal amt?
If I adjust the throws and put a low pitch prop on it, at 1st then re-adjust for aerobatics when she's ready, no need for a second plane.
Old 06-25-2003 | 04:08 PM
Many years ago when I first started flying I had a Falcon 56 (high wing) with dihedral. I eventually became rather good at handling that plane. It was 'predictable'. It could settle right in to the landing spot I selected.
When I then changed to a low wing with NO dihedral (constant cord) I DID notice a difference. The plane REQUIRED the wings to be consciously made horizontal. That is, when landing the plane did not 'settle' into 'wings level' flight over a given amount of time like the Falcon 56 did. I vividly remember thinking 'Gee, this sure is different'. And that was 20 some years ago! But then I always tended to notice things that others did not. I think that was because I liked to bring a plane in very, very slow (for a very short roll out) (like a bush pilot) and that is much trickier than bringing a plane in with typical, faster speed. So I was very sensitive to how the plane handled at very, very slow speeds. And at very slow speeds it was actually 'gliding in' under a little power, nose high (thus the wings were tilted up) to allow a smooth touchdown with minimal forward roll.
So maybe the dihedral is more noticeable at the very slow speeds and nose up conditions. This would make sense to me because in this situation the dihedral would attempt to act like feathers on an arrow. The odd part is that the faster planes I flew I built with the top of the tapered wings horizontal. This still introduced SOME amount of dihedral, but not much. I grew to like this type of setup because when I placed it in a turn it would stay there, even at very LOW speeds.
I have known many people that built their trainers with NO dihedral and had constant cord wings. Typical was the 'Sweet Stick'. They had no real problem learning to fly but they never landed at the extremely slow landing speeds I liked.
So I would not hesitate to suggest that you build the wing horizontal (no dihedral). Dihedral will not make a big difference to most people. Actually learning to fly using a wing with no dihedral will prepare the flier for pattern type and higher performance planes right from the get-go.
Old 06-25-2003 | 05:41 PM
Ed_Moorman's Avatar
Default Dihedral
I have instructed RC since the 1970's and I'd say it depends on your wife. If she has good hand-eye coordination, then skip the dihedral. Is she good at video games, does she play tennis well? Or is she an athletic klutz. You have to make this call.
As for a flat wing trainer, I'd go for the Avistar, which has a semi-symmetrical airfoil or a Stick. My buddy Ugo Ferrari has an Avistar with a flat wing and an OS .46FX. It sings and does everything except 3D. It still looks pretty nice, where as a Stick is, well, a Stick. As I recall, women tend to be bigger in the esthetics department than men.
Old 06-25-2003 | 07:12 PM
Keith,
Funny, I too had a Falcon 56. Crashed it many times. I think, like you said, I just don't notice it now as much as when I 1st learned to fly. I just pick up the TX and fly, no matter whether it's a delta, PBF or stick.
Ed_Moorman,
Yeah, she likes the ones that look like planes. I've got her training on RealFlight in the interim.
Thanks guys!
