Go Back  RCU Forums > RC Airplanes > Aerodynamics
 flutter fun >
flutter fun
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
flutter fun
Old 08-10-2009 | 02:27 PM
qwertypemdas's Avatar
Default flutter fun
I'm building a chloroplast plane. Well, the vert. and horizontal stabs are chloroplast. Some guys at the field have a cool sounding low pitched flutter in the tail. This is the stupidest question ever. How can I induce flutter?
Old 08-10-2009 | 05:27 PM
CrateCruncher's Avatar
Default RE: flutter fun
Short answer: increase the mass, lower the stiffness.
Old 08-10-2009 | 06:20 PM
> I'm building a chloroplast plane. <
I doubt that. You are actually buidling a coroplast plane. (G)
Old 08-10-2009 | 06:43 PM
ORIGINAL: qwertypemdas
Duplicate the tail that flutters. Make sure to duplicate their hinging too. If it doesn't flutter for you, then loosen up the connections from your servo to the horns.
Old 08-10-2009 | 06:54 PM
Have you ever seen a servo with the gears stripped from flutter? Kinda makes me wonder why anyone would want their airplane to be uncontrollable because it sounds "cool". Maybe you want to re-think this idea. Oh well, each to his own.
Old 08-12-2009 | 01:54 PM
opjose's Avatar
How about just putting in a plastic card piece edge on, affixed to the fuse, so it can create that "fluttering" noise in the wind for you?
That way you will not have to do anything as silly as TRYING to introduce flutter.
As long as one edge is held firmly and the other edge can flap around, you'll get that buzzing noise.
Much like, playing cards in a bicycle wheel....
Old 09-04-2009 | 07:28 PM
nmking09's Avatar
My Feedback: (61)
use loosley supported nyrod, that will cause flutter.
