Edge 540 .90 size
Why, when I attempt to hover, and start to go vertical ( and at low throttle), my left wing will drop prior to increasing the throttle to maintain vertical. Also when attempting to perform a large loop,
the left wing will drop on the front of the loop.
Thanks, guys !
Thanks, guys !
Check your plane for lateral balance. I'm assuming you have the AW Edge (that's the only .90 size I know of) I've seen a couple fly and both had 1/2 oz of lead on one wing tip.
