Go Back  RCU Forums > RC Airplanes > Aerodynamics
 wing loading >
wing loading
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
wing loading
Old 02-16-2010 | 02:20 PM
skyjockey's Avatar
Default wing loading
I remember reading somewhere that a better indicator of the fliability of an aircraft is the volumn (cube???) rather than the square (area???) of the wing. It has been so long since I read about it that I've forgotten how it was figured or where I read about it. Does anyone recall anything about this concept?
Old 02-16-2010 | 03:40 PM
Default RE: wing loading
Just Google Wing Cubic Loading, you will get lots of info including computations.
Old 02-16-2010 | 08:03 PM
BMatthews's Avatar
It's not so much a measure of flying ability but of a way to compare models of different sizes. If you have a 1/2A model and a giant sized model of the same design, just scaled up, that have a lot of flying habits in common then the cubic wing loading will likely compare quite closely between the two. However if you look at the normal area loading the 1/2A model will have a wing loading that is perhaps only 1/3 to 1/4 of the wing loading of the big model.
None of these methods is perfect by any means. But the cubic loading provides a closer comparison when looking at scaling a design.
Old 02-16-2010 | 09:38 PM
Lnewqban's Avatar
Here is a good article about cubic loading:
http://homepage.mac.com/kmyersefo/CWL/larry.htm
