COG Aerobird
I found the COG of my Bird. At least I think I did. I used the 25% .
My question is:Is the boom supposed to be parallel to the ground when it is balanced, or should I see a slight drop of the tail surfaces. As it stands, at 25% (30mm) the tail is just a tad out of parallel with the ground.. tail heavy?
Thanks..
Thanks..
25% might be a little too forward of a C. of G. for a conventional configuration airframe, such as the AeroBird. Try 30%, in my opinion.
But, after all is said and calculated, your best indicator is a few glide tests.
-Q.
-Q.
