Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Aileron dimensions >
Aileron dimensions
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Aileron dimensions
Old 06-15-2010 | 08:44 AM
Default Aileron dimensions
Hi Everybody,
how can I define the right dimensions for ailerons? Is there any kind of calculator or formula? I'm using XFLR5 and I can simulate the effects of deflect some control surface, but how can I know how effective the control surface is (I got the Total Roll Moment, but I don't know if its is good or not)?
Best Regards
Old 06-15-2010 | 11:10 AM
BMatthews's Avatar
Default RE: Aileron dimensions
There's no set amount. The size is set based on the style of flying you want to do with the model. But a couple of rules of thumb for basic styles are about 10 to 12% chord for full span strip ailerons when used on trainer and sport models. For regular ailerons about 15 to 20% of the chord for the outer 1/3 to 1/2 of the span will work fine.
Just don't look at the hardcore 3D and similar models as a guide. Those designs are intended to try to turn themselves inside out at low flying speeds so you often see full span ailerons of 25 to 40% of the chord.
