Airfoil coordinate format question
I found some airfoil coordinates I downloaded and stored in 1994, and they have an SOF file extension. It is the classic top coordinates on the left and bottom coordinates on the right, nose to tail, as seen in the below excerpt from the Eppler 197. I can't find any references to SOF, so if anyone happens to know what it is, please pass it on. Thanks,
- Erik
E197
31
0 0
.00318 .00789
.01104 .01683
.02335 .02633
.03996 .036
.06075 .04556
8.550999E-02 .05478
.11402 .06345
.14599 .07139
.18112 .07844
.21902 8.442001E-02
.25933 .08918
.30159 .0925
.34551 .09413
.39085 .09394
.43735 .09191
.48474 .08806
.53282 .08246
- Erik
E197
31
0 0
.00318 .00789
.01104 .01683
.02335 .02633
.03996 .036
.06075 .04556
8.550999E-02 .05478
.11402 .06345
.14599 .07139
.18112 .07844
.21902 8.442001E-02
.25933 .08918
.30159 .0925
.34551 .09413
.39085 .09394
.43735 .09191
.48474 .08806
.53282 .08246
Typically the horizontal coordinate is on the left and the vertical on the right. So that means you've only got about 1/4 of the coordinates here for what appears to be the upper surface since it peaks at 9'ish percent. The left column only goes to .53282 or 53.282% so that's why I'm sure you're missing 75% of the coordinates. If that's all you've got then this file is corrupt.
As for the extension there were no lack of airfoil plotting software solutions a few years back. But often the files were interchangeable just by changing the file extension to make the next program see it as being compatible. I think it's fair to say that these days, and thanks to Selig and his coworker's efforts, the "standard" is the Eppler format.
Hi Erik,
Check this link for the E197 coordinates:
http://www.ae.illinois.edu/m-selig/ads/coord/e197.dat
At this place, you can find how to plot the airfoil for any size:
http://www.profili2.com/eng/default.htm
The 197 coordinates are incomplete, as you noted. I just took a partial clip to show what I have and it is typical of the 100 or so SOF airfoils files.
It would be nice to know what the SOF means. Maybe it belongs to a particular airfoil plot program. Might even be an old DOS program.
The Eppler system is now the most common format, so the smart thing to do would be convert the SOF to a DAT format. I see several programs out there that claim to do that.
The Selig and UUIC database is absolutely awesome and certainly the ultimate airfoil data source for the serious modeler. Gee, why would anyone want to create a 'new' model airfoil considering what we have in our hands?
My goal is to organize all of this data I have downloaded over the years and eliminate the duplicates.
Thanks for the input!
- Erik
- Erik
ORIGINAL: LNEWQBAN
You are welcome, Erik.
Posts #1 and #2 made me believe you did not have the full coordinates.
- Erik
