RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Big mistake! Please help (https://www.rcuniverse.com/forum/aerodynamics-76/1399422-big-mistake-please-help.html)
Wynterhawk 01-03-2004 08:37 PM
I am building a spadstick. The wing chord was suppose to be 11" plus 2 5/8" for ailerons. Well I figured on 12" to add a few square inches of wing because I anticipated it might get a little heavy - anyway I set the spar at the measured place off the plans but forgot about the extra inch - the bottom line is that I have a wing with the spar at 31% of the chord (Including ailerons) instead of the normal 25% -
So the question is, do I scrap the wing or fly it?
The profile came out semi-semetrical with a total wing thickness of about 1 1/2" at the spar.
Any help would be greatly appreciated
Hawk
Kenny R 01-03-2004 10:36 PM
RE: Big mistake! Please help
That shouldn't cause you any trouble at all...fly it and have fun:D
Dewey2 01-03-2004 10:55 PM
thats fine. mine have been know to be a lot more off than that. i thought the cg of the spad 3d was 8.1/2 its spad that looks about right it will work they really don't care about small stuff like that as long as the props spinning there happy.:D
Mike James 01-04-2004 12:22 AM
Now you're an airfoil designer. Have fun.
crashnburn 01-14-2004 11:08 PM
If your worried about having your cg and the location of the spare-don't worry. You can still set the CG whever you want it-I don't think the spare loacation is really that critical.
