RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   thrust line question (https://www.rcuniverse.com/forum/aerodynamics-76/2024868-thrust-line-question.html)
dinger2 07-26-2004 11:55 AM
Hello all-
1/4 scale Dynaflight Flybaby- Saito 100
I scratch built a cowl, and I was a bit long- so instead of cutting the cowl, I added a 1/4 inch piece to my motor mount. In doing so, I threw the thrust line off center to the right by about 3/16. This plane already has about 3 degrees right thrust built in-
How critical is that 3/16 off the center thrust line? Suggestions? Or should I not sweat it? Comments appreciated-
Cheers,
Brett
Tall Paul 07-26-2004 12:50 PM
RE: thrust line question
I'd redo the mount.
LouW 07-26-2004 01:52 PM
Or cut the cowl.
dinger2 07-26-2004 02:55 PM
That's what I was afraid of- Thanks Gents-
Cheers,
Brett
