RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Engine position and Thrustline/ CG on A-10 (https://www.rcuniverse.com/forum/aerodynamics-76/3147403-engine-position-thrustline-cg-10-a.html)
sina 07-08-2005 07:35 AM
Hey you aerodynamics enginners:
Building an A-10 with twin .25FX engines that sit about 3 inches high off the trailing edge of the wing. If I were to make the engine platforms longer or were to raise them so that they have, oh about 4 to 6 inches clearance will I significantly change the thrustline or CG?
This is because you can't find props that are pitched enough but short enough to fly the plane.
Any help is appreciated.
Sina
Dr1Driver 07-08-2005 08:07 AM
RE: Engine position and Thrustline/ CG on A-10
Try a 3 blade prop. Moving the engines too much will seriously affect CG and thrustline.
Dr.1
Tall Paul 07-08-2005 11:11 AM
The thrustline change -will- have a large effect in the nose-down direction, but there shouldn't any problem with the c.g.
sina 07-10-2005 11:34 AM
sorry but can you elaborate - what do you mean by "The thrustline change -will- have a large effect in the nose-down direction"?
thanks a bunch...
Sina
Tall Paul 07-10-2005 11:49 AM
You'll be moving the motor up. This increases their leverage around the c.g. with the longer moment arm.
