RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   Aileron Throws CompARF Extra 2,6m (https://www.rcuniverse.com/forum/aerodynamics-76/3291516-aileron-throws-comparf-extra-2-6m.html)
Zeb_Macahan 08-23-2005 03:31 PM
I have a new Composite-ARF Extra 2,6 m and I think the 10% dif. between up- and downthrows ( on the aileron) that the instruction says can´t be right.
My Extra is not rolling nice when I use these throws. Has anyone got it dead on right???
John Murdoch 08-23-2005 04:02 PM
RE: Aileron Throws CompARF Extra 2,6m
Make sure you're using 10% NEGATIVE differential... That may be your problem.. You want the "down" side to go down 10% more than the "up" side.
Zeb_Macahan 08-23-2005 04:13 PM
Thanx John. Yes I have more down throw than up, but the vertical rolls look like crap. Of course I can try different amount of % but I use Hitec programmable servos and I already have max ATV on my radio so I have to reprogram my servos. I would be extremely happy if anyone had a number that seems to work so I only would have to programme she servos one more time. YES I´m LAZY:)
John Murdoch 08-23-2005 04:16 PM
Zeb.. I had mine set at 10%.. Then I tried 11% and 12%. I went back to 10% for the most axial roll and it worked best there. Are you setting your end points on the high or low rate?
Zeb_Macahan 08-23-2005 04:23 PM
I have the 10% at maximum throws. I have not measured the % at lowrate , but I suppose that I have 10% there also.?.?.
John Murdoch 08-23-2005 04:30 PM
Zeb.. I'm not sure what to tell you. By the way you've described your setup, it should be correct and negative 10% is the magic number. Or at least is was with the 2.6's I've flown.
Zeb_Macahan 08-23-2005 04:35 PM
John, if you are still there, did you ever try with same down and up throw? Or at least a smaller difference than 10%?
John Murdoch 08-23-2005 04:37 PM
Nope.. Started with 10% and then adjusted just for the fun of it to see what it would do. Rolls were ALWAYS better at the negative 10% setting.
Zeb_Macahan 08-23-2005 04:43 PM
Thanks for your help John. I have to check again that I have my 10%. That must work if you say so. Thanks again!
