RCU Forums
-   Aerodynamics (https://www.rcuniverse.com/forum/aerodynamics-76/)
-   -   will it loop? (https://www.rcuniverse.com/forum/aerodynamics-76/3701493-will-loop.html)
rmh 12-28-2005 04:50 PM
will it loop?
1 Attachment(s)
will it loop?
will it roll?
will it flatspin?
BMatthews 12-28-2005 06:09 PM
RE: will it loop?
It'll certainly knife edge... or would it be more accurate to say rim edge.... :D
Seeing something like that makes me want to drag out the sketch I did for the X winged "Which Way?" I did some time back....
rmh 12-28-2005 06:38 PM
RE: will it loop?
I flew it today - it is a friend's model -I made the extended gear for it . it feels very ordinary but needs more tail group authority.
It did get me thinking tho as the goal here is to have a twin screw setup --
So - ah will whack out a flat foam electric twin -with my own thoughts for lots of side area--- where it really counts -in a full sized airframe .
These little foam models are incredibly good for prototyping concepts -you can do the whole job in a day and get really meaningful results
The hooker here -is to be fully aerobatic, unlimited performance , with the torque rolls (?) flat spins/ tumbles / flat turns etc., as done with single prop setups .
Mine will have two motors - turning same direction--
