Thrust angle ?
Good Morning,
I am building my first from scratch design. Nothing to compliacted a basic balsa profile Kantana is the design. Just a personal knock off really. I haveand still do build with foam and thrust becomes more of an issue when the design is light. I did a search and found nothing regarding thrust angle here. Is there a formula available that helps or nails down dialing in the correct thrust angle. Anyone experieced with advise? I am not new to building ARF's or kits. I know some basics od design but I am no expert RC plane builder...yet. Just looking for a good start point for the motor thrust line. I will get it after experimantation and spacers but is there a good formula based on a planes paramaters. I have missed this right off in every prior attempt. Thanks Michael |
RE: Thrust angle ?
Set everything at zero.. thrust, wing and tail, if it's to be a 3D airplane.
| All times are GMT -8. The time now is 11:15 AM. |
