Finding wing area
I can't remember, do I count the ailerons as part of the wing cord (root and tip) when figuring wing area or just the wing itself?
RE: Finding wing area
Yes the ailerons count as area of the wing as well as the portion that is covered by the fuselage.
How dies a round fuselage between the wing halves create lift as much as the wing airfoil ? |
Here we go again..............[:o]
I found a free cool little program that I use to figure it out..... Simply enter the root cord and tip cord and it tells you wing area and wing loading (If you entered your planes weight).
[link=http://www.hoppenbrouwer-home.nl/ikarus/software/thrusthpv20d.htm]ThrustHP V 2.0d[/link] |
ORIGINAL: skylane_182 I found a free cool little program that I use to figure it out..... Simply enter the root cord and tip cord and it tells you wing area and wing loading (If you entered your planes weight). [link=http://www.hoppenbrouwer-home.nl/ikarus/software/thrusthpv20d.htm]ThrustHP V 2.0d[/link] and thanks to everyone for the input!!! |
ORIGINAL: LostMyPlane ORIGINAL: skylane_182 I found a free cool little program that I use to figure it out..... Simply enter the root cord and tip cord and it tells you wing area and wing loading (If you entered your planes weight). [link=http://www.hoppenbrouwer-home.nl/ikarus/software/thrusthpv20d.htm]ThrustHP V 2.0d[/link] and thanks to everyone for the input!!! |
cyclops2,
I believe the fuse does too little for lift to be considered. I don't consider it when I calculate wing loading, but as a convention, most of the designers consider the area of the wing covered by the fuse. Wing loading is just a number to give an idea of how much weight the plane is able to lift per unit of wing area; nothing exact, specially considering that different parts of the wing create lift forces of different magnitude. Check this thread out: http://www.rcuniverse.com/forum/m_95...tm.htm#9530648 |
ORIGINAL: cyclops2 How dies a round fuselage between the wing halves create lift as much as the wing airfoil ? Wing area is easily calculated by the formula (tip chord + root chord) / 2 x span = area . And if done in inches then the wing loading per sq foot is calculated by weight in ounces x (area/144) = wing loading in oz/sq foot. No online calculators needed. Just some simple math. |
:) Would not most people use a calculator to do that simple math anyway? Why not use one specifically for that purpose? And while I can not vouch for the accuracy of the Static Thrust calculator...it is kinda neat to play with [8D]
And if done in inches then the wing loading per sq foot is calculated by weight in ounces x (area/144) = wing loading in oz/sq foot. No online calculators needed. Just some simple math Should be the weight in oz divided by the area in sq ft. |
Oh is my face red.... Highplains you're entirely right and I goofed big time. I was so intent on the shift key and brackets that I goofed the equation badly.
Let's try Weight in ounces/(area in square inches/144)=wing loading in oz/sq foot. |
| All times are GMT -8. The time now is 07:24 AM. |
