.60-.90 ProX260 QB freestyle CG
NM
The manual says the cg is 5 1/8" back from the wing Leading Edge measured at the wing tip so when I check the cg at 5 1/8 it was just a little nose heavy so I took it out and flew it
and when I came in to land took the thottle all the way down the nose did not what to come down so came in with the nose up,this does meanthe tail is heavy right?
Steve
CO
RE: .60-.90 ProX260 QB freestyle CG
Steve,
We flew our shop ProX260 more this weekend with the 20cc DLE and I agree with the plane set at the 5 1/8” C.G. location it was slightly tail heavy. We moved the C.G. to 5” and it flew much better.
At the recommended 5 1/8” location the plane is set for extreme 3D flying
Hope this helps!
Rocco / Aeroworks
Hope this helps!
Rocco / Aeroworks
