Extra 260 Freestyle 30cc
BC, CANADA
Nice airframe.
Please consider options of Canister tunnel of future runs. Many of us use DLE engines, way too loud on stock muffler.
I know weight is considered, just add wood and room and instructions for those that need this. add 35 $ if needed, whatever, offer it !!!
This is one of the best 30cc 3D Planes out, dont ignore this request. Almost all the budget 30cc planes have a tunnel for pipe or canister.
I modified mine to fit DLE 35 canister and likely lost it due to heat build up inside fuse []
Please don't ignore, this is a real request and necessity for many fliers and fields!!
CO
RE: Extra 260 Freestyle 30cc
Hello Nitro Wing,
Thank you for your great comments and suggestions. When designing the 30cc Freestyle 260 weight was a big issue and this was the main reason for not adding the canister tunnel. All of our regular QB (Quick Build) aircraft have tunnel and hardware for installing canister and pipe and this does increase the weight of the planes. It is obviously a great help for those wanting to install a canister or pipe but a weight penalty for those who do not. When talking with many of our customers weight was the biggest factor for most. So with our QB-L (Quick Build Light) series when designing the planes weight is or main objective. But I will look into it on future projects.
Thank you again for all your support!
Rocco
Aeroworks
Rocco
Aeroworks
BC, CANADA
On future runs, it would be nice to have the plane slightly re designed to accept the tunnel and simply provide a few sheets of pre cut wood, so one can install the tunnel if needed, that would be the best way, leaving the option to the customer.
Hi has anyone foung that the given weight for this plane is wrong. I have mine and it comes out at 14lb . and i have a lighter engine than is suggested ,Lighter servo's . setup is different only in that i have a canister which is only 40 grams more than the stock muffler. and 2 batteries instead of 1 which is another 120 grames so thats an extra 160grames more but with the 35 grams saved on servo weight and the 12 grames saved on the engine then i should be 113 grams heavier than the sock weight of 10.5lb to 11lb .I have even removed the spats to save a few grams. So i think the weight of the model is coming from the factory are using heavier wood than was used with the original plane.
What are other peoples weight coming out as and with what setup.
Martin
Martin
