60cc Freestyle Extra 260 QB-L - New Flight Video Just Posted!
CO
Hello Everyone,
Here is the flight video of the New Aeroworks 60cc Freestyle 260 flown by Andrew Grant aka VoroRC.
Don't miss Andrew along with fellow Aeroworks Team Pilots -Jonathan Jennings and Tyler McCormick at Joe Nall flying the new 60cc Freestyle powered by the Awesome DA70.
https://www.youtube.com/watch?v=dOHdDQTNCMM
You can visit our web site for even more details: http://aero-works.net/store/detail.aspx?ID=561
Thank You,
Rocco
Thank You,
Rocco
CO
Hello Everyone,
Here is the second flight video of the New Aeroworks 60cc Freestyle 260 flown by Andrew Grant aka VoroRC.
Don't miss Andrew along with fellow Aeroworks Team Pilot -Jonathan Jennings at this years King 50 flying the 60cc Freestyle!
https://www.youtube.com/watch?v=qaFO...26ZY-zThiR9dYg
Thank You,
Rocco
Thank You,
Rocco
CO
Hello Everyone,
Here is another flight video of the New Aeroworks 60cc Freestyle 260 flown by Johnathan Jennings.
https://www.youtube.com/watch?v=w5Xr...ature=youtu.be
Thank you
Rocco
Aeroworks
Thank you
Rocco
Aeroworks
CO
I wanted to give a special thanks to team pilot Johnathan Jennings for his awesome flight this past weekend at the NOF 3D Tour. Johnathan took 2[SUP]nd[/SUP] place flying our new 60cc Freestyle Extra 260 QB-L……. Great flying Johnathan!
https://www.youtube.com/watch?v=GAj2m7WKdfc
Congratulations to all the pilots and thank you for putting on such a great show!
Rocco
AeroWorks
Rocco
AeroWorks
CO
I finally finished my Extra 260 Freestyle. It's taken me way too long.
I let Andrew Grant use my motor for the King 50 Flying event, and have been looking into a HV setup and newer servos. I tried several different servos and did not like some compared to what I settled for. Maiden Day was 9-21-14.
Got the plane all trimmed out and could not believe at how well the plane tracked. My setup is a little tail heavy, but not much. The Pitts muffler may have helped with instead of the stock muffler. Also, I may add a Tru-Turn aluminum spinner. The carbon gear would be nice but is not necessary as I need the little extra from the stock gear. If I add a carbon tail wheel this may help with my cg.
I will resolve this. I used the Blazing Star engine mount which is 1.50 inches.
I still need about a washer or tad more to have my spinner clear the cowl. I was afraid the spinner would rub as it is very close. My Compact muffler works to clear the cowl, but the corner is just touching it. I will have to open a small hole in the cowl to relieve this. The Pitts muffler would clear and works great.
It would add a little of nose weight also. I just was looking for a very clean and cool look with the louvers I cut into the cowl. I will add one or two washers between the engine and mount to push the motor forward.
Update: 10-8-2014
Relieved the cowl where the muffler rubbed. Also, I added a Tru-Turn Aluminum spinner with a solid back plate for nose weight. I flew it on 10-5-14 and it worked great. Before I had 7 clicks of down, now I have 1 click of down.
Aeroworks Did a Fantastic job of designing a great 3D Freestyle Plane. The Plane dose track very well also. If you are into High Energy 3D stuff, this is the plane! I did a few mod's. Check out my pictures.
Here's what I settled for:
DA60
Blazing Star Aluminum engine mount / spacer
JTec stock muffler custom compacted
Falcon 24x9 carbon prop
Home made Fiji 16 ounce tank
Hitec HS7950TH servos
SWB servo arms, 1.50's on aileron, 2'' on elevator, and a 3 inch on rudder.
Spektrum AR9110 Power Safe receiver
Smart Fly Pin Flag Switch
Thunder Power 2s 2700mah Prolite Lipo's x 2 for power
Tech Aero Ultra IBEC for Ignition
Kavan 3.50'' Tires
Tru-Turn 3.50'' P-51 Aluminum spinner, solid backplate
AUW 17.4 lbs, no fuel
Cory
Here's a video of me Flying mine and Tossing it around. It's a Fun Plane.
It flies and tracks great, but I like doing the 3D stuff the most.
http://youtu.be/_45N_VKBMns
Update: 10-8-2014
DA60
Kavan 3.50'' Tires
Cory
CO
The 120cc Freestyle’s are in production and I expect to have them in stock late December. We have been working hard to finalize our new web site and I will have the plane listed on the new site….
We plane on launching the new site in the next few days!
Thank you,
Rocco
Aeroworks
Thank you,
Rocco
Aeroworks
