Introducing the NEW Aeroworks Pitts Python ARF QB!!!
Introducing the Aeroworks 50cc Pitts Python ARF QB! This new desighn is sure to impress both on the ground and in the air! Be sure to visit us in Toledo this weekend to check out this and other new products from Aeroworks.
Specs:
Wing Span 70"
Wing Area 1656
Length rudder to spinner 72.5"
Engine 50cc
Weight 17.5 pounds
Intro Price $699.95 plus S&H
We would also like to thank Bob Trueworthy for the use of his color scheme.
Specs:
Wing Span 70"
Wing Area 1656
Engine 50cc
Weight 17.5 pounds
ORIGINAL: bubbagates
Finally, a 50cc Python,
I just checked the site, when will they be available...I want one bad
Smooth move guys,Looks good but is it the pics or is the nose a lil thin ? Other pythons look like they havemuch bigger around fuse and nose. or is it pics> great job and thanks for the QB series , you hit a home run with these arfs, excellent quality, nice fit and finish. you have a repeat customer here. Now make it bigger......lol
On a second look.... is there any airfoil on the horizontal or vertical stab? They look flat. For $700, I would want airfoiled surfaces.
The stabs are flat on the "full scale" airplane.
ORIGINAL: reyn3545
My Feedback: (16)
ORIGINAL: reyn3545
Yes they are flat tails because the full size has a flat tail.....
John@Aero-Works
FL
ORIGINAL: John@Aero-Works
John@Aero-Works
John@Aero-Works
Not exactly. Full size does not have a flat tail. Stab tapers thicker to the hinge line and the elevators taper from that thickness to very thin at the trailing edge.
Kevin Kimball
My Feedback: (32)
from the Pitts Python web site. The stabs sure look flat to me
http://www.aircraftstudiodesign.com/...on/gallery.php
I'm not as particular about trueness to scale as I am about warps... not a problem in the full scale, but I don't know if I've ever gotten a plane with flat surfaces that were truly flat.
ORIGINAL: reyn3545
My Feedback: (16)
ORIGINAL: KJKimball
Kevin Kimball
John@Aero-Works
John@Aero-Works
Kevin Kimball
True but my reply is, that the full scale does not have a air foiled tail.
I'll wait on some feedback from the production units.. if they're stiff enough to prevent warping, it shouldn't be a problem. Out of curiosity.. why the Python style? Longer fuse for better control?
TN
HI, I just got back from the Toledo show. This plane is nice, The pictures dont even come close to showing off this awsome bid. I will be putting in a order for one as soon as aeroworks takes them. To bad its going to be awhile befor they are in. Real nice job on this plane guys.!!!
My Feedback: (18)
Is there any concerns about the stabs needing flying wires since they are flat and not airfoiled, Im not hung up on airfoiled stabs, I think flat stabs fly just fine. I had one of the old 29% edges it had a flat stab and flew great. thanks Tim
My Lanier uses flying wires.. they seem to do a great job of keeping everything squared up. I guess if you had problems with warping or the surfaces washing out on you under stress, it would be a pretty simple process to make and attach some for this plane. I can't wait to read some of the build threads and see what folks think. I guess it will be a few months, though.
Is that the actual cowl that the production plane will have? I've heard rumors it'll be revised to look like an actual Python for the production plane.
