horn availability?
Hi Mark, or Aeroworks rep,
I have a 90-120 Yak. It flies great!! I also have a couple of other Aeroworks aircraft and they are all great!!
My 90-120 Yak has single control horns, this setup is probably quite sufficient for the application, however all of my other AW arfs have a double control horn setup.
I very much like the double control horn setup and would like to obtain some additional control horns in order to sandwich a ball link between the horns on the ailerons, rudder and elevator.
I was unable to find the control horns in your Accessories area and was wondering if it is possible to get some.
I aslo have a question about the hardpoints. Do the hardpoints on the 90-120 Yak support the use of a double control horn installation? This would be an outstanding change for this arf. Not that it is neccessary, but would sure add big secure feeling to the aircraft. And the additional weight would be nothing!!
Thanks in advance for your reply
MR G
MR G
