SD 10 G Issue with dual Ele. Servos
I have an SD10G that is 14 months old that I use in a 2 m Pattern plane with dual elevator servos in the stabs . I am using the 7 Ch. reciever. The reciever was also new at this time.
I am having an issue with the right side elevator half not staying centered and matched to the left . I thought I had a bad servo so I replaced them with new JR 3421s after 3 flights the right half is up again as compaired to the, left about 1/4 inch . This has happened 4 times in the last week.
I can not find anything loose or worn in the stab itself ,everything is tight.
I have used this setup for many years with no problems.Nothing else has been affected the ailerons that also use dual servos are working fine. So any ideas as to what might be causing this ? Have there been any issues with dual servos that anyone has heard about ?
