sd-6g range problem?
Hi there. Have a SD-6G end use 9224 receiver. Once lost control of plane and after that made a simple test. Going 500 meters or 547 yards away from plane on a flat street I lost signal. At 300 meters signal was back again. This test was done with a different from the one used when lost control. Battery was recharged both on tx and rx before test. Would it be normal behavior? Best regards
