Airtronics SD10G- Timer
Yes, there is.
SD-10G AERO
Procedure for programming a Sick Switch for Start-Stop operation of the Timer function
of the SD-10G Transmitter.
Select SYSTEM using the Navigation Pad. Press ENTER.
Scroll down using the Navigation Pad and highlight TIMER. Press ENTER.
Highlight Stop Watch and press ENTER.
Set your desired Minutes and Seconds using Navigation Pad and the YES/+ key.
Press the END key three times.
Highlight SYSTEM and press the ENTER key.
Scroll down using the Navigation Pad to SWitch ASSIGN. Press ENTER.
Scroll down to START. Use the YES/+ key to set START to S1 and set STOP to S2.
Press the END key twice. Press the ENTER key to access the SYSTEM menu.
Scroll down to STICK SWITCH and press the ENTER key.
STICK SWITCH >1
Set STICK >TH using the Navigation Pad and Yes/+ key. Move the THROTTLE STICK to a high
throttle position so STICK reads 56%. Highlight POINT. Press the YES/+ key to make it read POINT
> -56%. This is the ON point for the Timer. The display will indicate:STICK >TH
POINT >56%STICK
56%
SWON>HSOUND>INHONMove the THROTTLE STICK down to the extreme Low Throttle position, and move the cursor down
to ON>H. If it does not read ON>H, press the YES/+ key to change it. The display will then indicate:STICK >TH
POINT >56%STICK
-100%
SWON>HSOUND >INHOFFUse the Navigation Pad and the YES/+ key to select STICK SWITCH 2. With the THROTTLE
STICK the in the Extreme LOW throttle position, scroll down and set POINT –100% using the YES/+
key and display reads ON >L. The display should then indicate:STICK >TH
POINT >-100%
ON >L
SOUND >INHSTICK
-100%
SW
ONPress the END key twice to return to the main display.
Your Timer Minutes and Seconds are shown on the LCD Display.
When you move the THROTTLE STICK above 56% The Timer will start. When you move it to the
LOW Throttle position the Timer will stop. When the Timer counts down and reaches 10 seconds it will
sound a note at each second and a final note when it reaches zero seconds and begins counting up. After
the completion of your flight press the YES/+ and NO/- keys simultaneously to reset the time to your start
time.
Jack R. Albrecht
Airtronics Technical Support
Revised 17 August 2009
SD-10G AERO
STICK SWITCH >1
POINT >56%STICK
56%
POINT >56%STICK
-100%
POINT >-100%
ON >L
SOUND >INHSTICK
-100%
SW
time.
Jack R. Albrecht
