Airtronics SD10G and servos
Hi, has anyone tryed SAVOX o HI TEC Servos with this transmitter and 7 channel reciever?
Any compatibility issues?
Regards
Eduardo
Regards
Eduardo
I have a SD10 G but i'm not aware of a setting to fix analog servos glitching that occurs with the 10 ch receiver, the 7 ch receiver however should be fine with all servos.
Here’s what the manual says...there is no way to force the 10ch FHSS-3 receiver to work with analog servos, at least it is not shown in the manual. If you figure it out, let us know.
Moderator
So it's FHSS-1 which requires different receivers. I had this radio for several years and never had a problem with my servos, but was aware there was a fix for it.
