*Airtronics RD8000 2.4 GHz*
#976
RE: *Airtronics RD8000 2.4 GHz*
I won't debate what you have said Mike because I'm not knowledgeable enough on batteries but in my 40 years of flying radio control I've never seen batteries act like these nor have I seen nicds discharge this fast under no load (on the shelf). I have seen nimh do this when they first came out for RC use 25 years ago. And I've not seen a battery tester that does not go red at less than 9.4 volts. I don't believe you would suggest that I fly when a battery tester is well in the red. Also the battery low alarm on the RDS8000 is set at 9.5 volts and the instructions say to land immediately
I fast charge AAs at 300 to 500 milliamps. I slow charge with an Airtronics wall charger 75milliamps.
I just tested a nicd out of one of my RD6000 (600 millamps) that hasn't been charged in over a month and it's in the green. I will admit I haven't checked the remaining capacity in one of the new batteries that has dropped to 9.6 while setting on the shelf. I will do this and report.
#977
The radio has a year warranty. If you think the battery is defective send it back and we'll replace it.
I'm just saying that the radio will work down to 9.0V safely and that the pack at 9.6V is safe to use. And unlike lipo's or some of the other newer batteries, nicd batteries are not going to hold voltage much above nominal voltage in storage for very long.
#978
Not saying the battery is defective, just different and at this point disconcerting until I've tested capacity when it's settled at 9.6 on the shelf. You well note that I altered my previous post to point out that the low voltage alarm is set at 9.5 volts on the RDS8000. When I test for capacity I take the voltage of the individual cells down to 1 volt. I will also check to see when the 9.6 drops to 9.5 under load, 300 milliamps.
#979
My Feedback: (8)
How do you get spoilerons to work properly on this radio? I get flaperons to work fine, but the spoileron function doesn't make the ailerons move with the 3 position toggle switch, causes the throttle cut to stop working, and makes the trainer switch work as a throttle cut. I understand that if flaperons are on, spoilerons are off, and vice-versa.
Also my battery alarm comes on way before the radio hits 9.0 volts, which I thought was odd. Is there a way to change that?
#980
My RDS8000 transmitter batteries (I also have two) seem to self-discharge a bit more quickly than the tx batteries that came with my Futaba radios. The only knock I've read about Airtronics here on the RCU forums was that some folks said Sanwa batteries weren't as good as other OEM packs. The Sanwa packs that came with my RDS8000 seem to hold a peak charge OK for a day or so, but if you haven't charged the transmitter for three days or so, the voltage will have dropped down to a few tenths of a volt above nominal.
Having used my radios for a bit, they seem to charge and discharge the same as my Futaba tx packs do. The voltage rating is as high after a full charge, both brands seem to top out around 11.1 or 11.2 volts. The Futaba tx batteries (according to my 7C anyway) will operate from around 10.7v to 10.0v or 9.9v during an hour or two of flying after being topped up. The Sanwa tx batteries drop quickly down into the 10.3 or 10.2 volt range and operate closer to 9.8 to 9.6v after an hour or two of flying.
Do the Sanwa batteries not hold a charge as well, or is the voltmeter reading built into my Futaba 7C simply a bit "optimistic?" The voltage behavior of the Sanwa packs in my RDS8000s actually seem more "normal" for NiCd batteries to me.
At the end of the day, I don't really know that it matters. The RDS8000 operates perfectly fine at full range with the voltage indicated in the 9.6 volt range. My flight times aren't affected and I don't have to recharge my Airtronics radios any more often than my Futabas.
With other radio systems, I know pilots who get nervous if their 9.6v tx battery reads 9.6v. With the Airtronics RDS8000, you don't appear to need any extra voltage for a solid and reliable link. I believe this is more of a difference in how the different brands of transmitters function than any indication of an inherent problem with Sanwa transmitter packs.
I'd be more concerned if I owned a transmitter that came with a 9.6v tx battery but wasn't safe to fly when the battery was at 9.6v. As a Futaba flyer for the last several years, I'm comfortable with the tx battery performance of RDS8000 radios and I believe that they probably provide a more accurate rating of tx battery voltage than my Futaba 7CAF does.
#981
The general idea behind the voltage warning is that if the battery has hit 9.4 or so, it's going to "dump". The Discharge curve gets really steep right at the end.
So, better safe than sorry.
Anyway my point about the 9.0V is that if the battery does start to dump, you have plenty of warning because even at 9.0V the radio is working. It's making an annoying beeping noise, but it's working, thus don't panic. Just land safely as time/space on the runway permits.
If you're getting a short run time before the alarm comes on, then maybe the battery is bad. If it gets to 9.7 or 9.6 and then sits there for an hour (which is kinda' what the discharge curve looks like) then you're fine.
You might just try charging the night before, which is what we always recommend. Then fly sometime that day until you hear the beeping noise. Or, if you're all flown out and the battery still hasn't hit 9.4 then I think it's ok.
If I drew the curve for these batteries and perhaps some others I think what you'd find is that these batteries have a slightly lower average voltage but they stay well above the point when the battery warning goes off and provide a proper amount of run time. And since the radio will run at 9.0V, that means that you still have a big safety margin.
Does that make sense?
Mike
Mike
#982
My Feedback: (67)
MA
On my RD8000 the stock battery life was terrible 4 or 5 flights the most before reaching 9.7v. I have since switched to a 2200 mah nimh pack which solved all of my radio voltage issues. Upon receiving my RDS I instantly swapped out the original battery for the 2200mah nimh pack and I must say the RDS radio sips voltage compared to my RD. With my RDS I can fly for 2 weekends 2-3 flights each time and not have to charge the radio. In fact I have never seen voltage in the 9's with this set-up.
#984
My Feedback: (21)
ORIGINAL: gaRCfield
#985
My Feedback: (8)
ORIGINAL: mrbigg
I don't understand why the deal about the throttle/trainer switch. Never had that problem. Are you running dual aileron servos? What ports are they plugged into the reciever? Both channels have to be functioning the same way. Either both normal or reversed. In the "etc" menu, FLAPE needs to be ACT and SPOIR needs to be INH. Double check and let me know whats going on when you hit the switch.
This is how my current setup is - left aileron in ch2, rt aileron in ch6, and flaperons turned on. Flaperons are working well. My question is about spoilerons though - when I turn on spoilerons, flaperons goes off, then the three way switch on the top right of the Tx does nothing, the throttle cut does nothing, and the trainer switch operates the throttle. In the directions it seems like spoilerons is meant for gliders, so I assumed that it wouldn't work for a powered plane because of this, hence changes with throttle buttons.
ORIGINAL: gaRCfield
#986
Where does it say the low battery alarm is set for 9.5V? The manual I have says that when the "gas gauge" is below half and it states "9.2V", it is time to recharge. The JR radios I have go down to 8.8 V (1.1 V per cell) before the alarm goes off. I was flying my RDS down to 9.2V last week and no alarm. And if I remember, the "gas gauge" was at 3/4.
Djlyon, is your battery tester putting a load on the battery? If not, it does not mean much, just as red and green ranges don;t really mean a lot. NiCads (TM) lose about 1% a day. As Mike said, I would never fly without charging before. I do, however, keep all my batteries on trickle charge after a full charging so they are always ready to go.
Going back to my JR;s, I always used an Accu Cycle. They would drain the battery, showing how many mAh were left, along with how many minutes. Once the cells get down to 1.1 V each, it charges for 16 hours and then goes to trickle. The Airtronics TX has a diode or something so this can not be done without removing the battery. This was the basic Accu Cycle you can get from Tower and it did no peak charging. My Accu Cycle Elite will do all that, but not sure it is necessary or worth the extra money.
bob
bob
#987
My Feedback: (21)
ORIGINAL: gaRCfield
ORIGINAL: mrbigg
ORIGINAL: gaRCfield
To set up spoilerons (assuming both ailerons drop when hitting the switch) First push the switch down (away from yourself). Do the ailerons drop when doing that? If so, remove the screws from the servos so that you can remove the servo arms. Leave the switch down, center the aileron by hand, hold it there while reattaching the servo arm. Do both sides. Now try the switch. Full down is neutral, middle is up, top is full up.
#988
When I'm using Ailerons also as Flaps And Spoilers, I simply use the flaperon, and then setup neutral on the 3 position flap switch in the middle. So then flipping the switch one way makes both ailerons droop (flaps) and flipping it the other way makes them both go up (spoilers) but of course they still wiggle when I move the aileron stick.
They're not variable or anything, it's just a 3 position switch, but it worked ok on the plane I had them on (kinda' a big high wing trainer that landed way better with some spoilers and in the air was a lot of fun with the ailerons both drooping...)
Not sure if this helps but I think it might be what you're trying to do and anyway, it worked for me.. If you need further help, you might call the 800 line on Monday and talk to Jack about it.
Mike
Mike
#989
Page 10 of the RDS8000 instruction book says the warning will go off when the battery voltage falls below 9.5 volts. If it's called a battery tester it puts on a load. Mine puts on 300milliamps. If it doesn't put on a load it's called a voltmeter.
Denis
Denis
#990
Well.... I signed up on RCU just to get into this discussion. I purchased the RDS8000 with the two receivers from HobbyPeople and to tell you the truth, I am VERY unhappy with this radio. I wanted to jump on the 2.4 band wagon. I have lost two airplanes because of the radio loosing signal with the receiver. Even after properly range testing. Both were planes that I have used 72mhz radios in with no problems. I also get the occasional error message on screen "TH-Hi" (Yes, the throttle gimbal is set all the way down before turning the radio on)
I decided that I dont want this radio, nor could I trust it. I have been in an email battle with Hobby People because I want a refund (or store credit) so I can purchase another radio. They wont give me store credit. (This is before the 30 day since I received it) They want to repair it and wont take it back because it it "Used". Let me ask anyone here, Would you trust this radio again? After loosing two planes and hundreds of dollars? I think not!!!!!!! Anyone have any suggestions on what to do???
#991
I hate to say it but I think Sanwa is buying their Tx batteries from the lowest bidder. I have had by RDS 8000 for a few months now and have noticed a few anomalies. I charged it three weeks ago and got in one short flight before the wind got too strong. This afternoon after reading a few of the comments in this thread I went out and set my cycler for a 200 mA load and hit the start button, the voltage immediately dropped to two volts or so and alarmed. Battery was dead flat, I have one Tx with a six year old NiCD in it that would still have had 2 or 300 mAH left in it in the same situation. [][]...........RJ
Ooops, sorry guys, I just realized that the battery is probably diode protected, kind of surprised me as none of my Airtronics Tx (Vanguard, Quaser, and Infinity) have the diode.
[8D][8D]..........RJ
#992
Lowesinstaller: You can pm me directly or email me if you feel you need further help.
Obviously if the radio is having a problem it needs to be returned either way. You certainly can't fly with it if it is not working properly.
Mike Greenshields
Global/Airtronics
Mike Greenshields
Global/Airtronics
#993
My Feedback: (9)
CA
Mike Greenshields
What is the range of the RDS8000?
Some say as far as the eye can see...for a normal person that is a little less than a 1/2 mile.
Shubova
[8D]
Shubova
[8D]
#994
My Feedback: (21)
ORIGINAL: MikeGreenshields
Mike
Mike
#995
My Feedback: (21)
ORIGINAL: Lowesinstaller
#996
My Feedback: (21)
PA
Shubova,
You have asked this question already 2 - 3 times on this and another thread and you have been told that the radios range is beyond the pilots ability to see the plane. Check the first 2 pages of this thread on Mike's reports of the range testing. This is a FULL RANGE radio. Unless you are planning to do some instrument flying with an onboard camera for visual I fail to see what you are concerned about. If someone has told you that this radio lacks range they are very mistaken.
#997
My Feedback: (21)
PA
Lowesinstaller,
I'm a little confused on why you would take a second plane up after you already lost one aircraft due to the transmitter "unbinding" with the receiver. To answer your question on what you should do, you should do what Mike said and send the radio in to be checked out along with the 2 receivers. If they find a problem with the radio that they haven't encountered before then it benefits all of us who already own the radio and future buyers of the radio when a problem is identified and rectified. You have a warrenty so use it. They'll probably just send you a new radio anyway. Btw, there have been very few problems reported with this radio so yes, I would trust the radio if they sent a new one. Passing a ground range check isn't a 100% gaurantee that something won't go wrong in the air. Signals to the receiver can be blocked once in the air during certain orientations of the plane due to faulty installation of the antennas <they must be 90 degrees from each other> or using carbon fiber fuselages or having carbon fiber inside of the fuselage. Let us know how you make out with this situation.
#998
My Feedback: (87)
A gentleman showed up at our local field a few weeks ago with a 43cc gas engine 80" plane ready to fly. His first larger plane. The club asked me to look it over for him and do a pre-flight inspection. Good gosh....the receiver wasn't installed properly. The receiver was resting (not even fastened down!) on the edge of the servo tray, with the twin 2.4 antennas literally hanging in the air, parallel to each other, aimed toward the nose of the plane. There were a dozen other issues I discovered as a result of careless, sloppy assembly, including undersized servos, undersized battery pack, uninstalled linkages, etc, etc.
My point is that his plane would have crashed very quickly, having had nothing to do with the 2.4 radio he used but as a result of how it was improperly installed. 2.4 is different and we need to respect those differences from 72mHz.
As others have requested, I'd sure like to have seen photos of LowestInstaller's original installation, along with post-crash photos.
Oh....that particular local pilot crashed 4 additional planes in the subsequent 2 weeks. All assembly and pilot error issues.
#999
My Feedback: (21)
PA
RCAddiction,
It sounds like you guys need to ban that guy from your field forever for the safety of everyone!!!! I agree with you 100% on the situation with bad receiver installations on 2.4. I think it will probably take another year or two for the vast majority of our flyers to finally realize that 2.4 IS different from what we got very used to with 72mHz. I've actually seen guys trying to make the arguement that the placement of the antennas at 90 degrees from each other wasn't really necessary because "they" didn't bother doing it and haven't "had a problem" yet. With a system that can become "blinded" by a solid object <like a large gas ignition engine> the antenna diversity is critical.
It would have been interesting to have had a little more detail from LowesInstaller like what kind of airplanes he had the radio system in and if after the crashes he tried to see if the system worked on the bench or did the receivers really loose the bind with the transmitter?
#1000
Crazy8s,
I didn't take any pictures. The one plane is a total loss, the other I am in the process of repairing. As I told Mike, I am not mad about the radio. I am mad about the way HobbyPeople are handling it. We all know that if you want to be in this hobby you have to expect good days and bad days. I didn't even think to take pictures. This is my first time using a 2.4 radio. Could it be installation issues? Anything is possible... It is very difficult to have proper antenna placement in a 40-60 size plane. I used pieces of fuel line to hold the two antenna leads at the correct attitude. Again... Both planes flew with 72mhz radios with no issues.
