what 2.4 article
#102
I can still keep track of that out to about 100 yards or so. It was quite a ways out, farther than my old AM set would reliably work.
#104
ORIGINAL: Sport_Pilot
Airplanes operate as much as over 30 time the distance of 100 yards.
9,000 feet? That is impressive by any standard.
The farthest I have ever been with an RC plane was a 3.8 meter glider with a GPS logger in it. I reached a distance of 3,100 feet laterally and 2,800 feet vertically. That is a line of sight (slant) range of 4,177 feet. I was losing sight of it for half of every turn in the thermal I was in. I would need a telescope to see a plane 9,000 feet away from me!!
#105
Banned
ORIGINAL: capt1597
i also totally agree with oberst! what he is trying to discuss is dead on! how do i know? had a nice talk with my little brother. he is an electrical engineer at JPL. he is a inter-planetary comunication specialist at JPL (talk about radio control toys). the nice thing is he dose not have any thing to sell and he is ''the man'' with the tech knowledge. in laymans terms, that are grossly symplified, 2.4, which is also cell phones, has disconect problems, and fm has ''stepped on'' issuses. if one flys in areas where there are no interference fm wins hands down. all the rest of these arguments seem to fall in the area of ''follow the money''. personally i still am flying my fm-pcm radios because i have never been shot down where i fly (that falls in the ''don't fix what ain't broke'' group.
ORIGINAL: Dave
I TOTALLY AGREE WITH OBERST
I worked for AT&T for 4 years. At the time I worked at the office we were getting sued because we had the saying that we had the least dropped calls. (That was about the time we bought out Cingular and just before we had the monopoly over the first I-phone) Yes the 2.4 is used by wireless- cordless phones wireless headsets and BlueTooth. Another reason why the 2.4 will be replaced is because the AMA is worried that the FCC will crack down on the hobby using the 2.4 besides the other issues pertaining to radio failures.
So yes, I know Cell, TDMA, G 1-5.
Verizon was about to hire me but I refused to pay union dues, and was refused hire. When I worked for AT&T belonging to the union wasn't required. (Off Subject)
The reason is what I was told is the phone companies owns the rites of the 2.4 band and when they start to complain it could be a major issue with the AMA and the FCC. Don't know how true it is, but it does makes sense because the phone companies were the first to use the 2.4GHz.
Now I really know why clubs are posting new signs stating to turn off all wireless phones! The water is becoming a little less murky now.
Pete
#106
Typo, should have been 20 times. However, I believe that 9000 feet is possible with a good transmitter and sensitive reciever.
I am serious about the primary and seconary user. I have heard this or seen it before and may need to refresh my memory of just what that is and how it works. It may have to do with the commericial use I discussed.</p>
#107
#108
ORIGINAL: Oberst
Our stuff is in the ISM 2.4GHz band. Is that where cell phones operate? I thought they were on the GSM 850 and GSM 1900 bands?
#109
Refresh away, but I quoted the exact FCC Rule and it is crystal clear. We are not, and never have been, primary users of our slice of the 72MH spectrum.
The AMA fought to get those 72 Mhz frequencies. Nobody but the FCC controls them. The FCC allowed them to run the gold sticker program to get people moved into the frequencies. So they have some clout, but not control.
I don't think the article said you could not have great range over water. It was that the range would be reduced or non existant, especially over water, in areaswhere there is large interference from other users, both RC and non RC.
#110
Our stuff is in the ISM <font color="#000000">2.4GHz</font> band. Is that where cell phones operate? I thought they were on the GSM 850 and GSM 1900 bands? <span class="info"></span>
#111
Hope this helps.......
47CFR95.207 (d) Your R/C station must stop trans- mitting if it interferes with: (1) Authorized radio operations in the 72–76 MHz band; or (2) Television reception on TV Chan- nels 4 or 5. (g) Stations in the 72–76 MHz range are subject to the condition that inteference will not be caused to the remote control of industrial equipment operating on the same or adjacent fre- quencies or to the reception of tele- vision transmissions on Channels 4 and 5. These frequencies are not afforded any protection from interference due to the operation of fixed and mobile stations in other services assigned to the same or adjacent frequencies.
There are Primary (licensed) users of 72mhz which are usually industrial remote control cranes or railroad crossing gates. We are Secondary (unlicensed) users of 72mhz and by regulation have to accept any interference from Primary users without interfering in any way with them.
Brad
Brad
#112
No you did not quote the part of the FCC explaining primary and secondary, that is prossibly in the definitions section. I presently do not have time to search for that.
#113
Blue tooth, WIFI, and other devices use 2.4.
Our stuff is in the ISM <font color=''#000000''>2.4GHz</font> band. Is that where cell phones operate? I thought they were on the GSM 850 and GSM 1900 bands? <span class=''info''></span>
Yes, I know. But the point I was responding to was speaking specifically about cell phones. Those are NOT on the 2.4 band.
#114
Banned
My Feedback: (9)
ORIGINAL: Oberst
However, if you tweek the regenerative with a tweeker, the flux capacitor you should observe about 50 ohm's out of the 27 MC tube improving it to the superheterodyne apparatus. That's of coarse if you buy the thinywatchamacallit regenerative receiver then the olfangletoot rays should hold long as it's grounded to the 27 MC tube transmitter. All the superheterodyne is or a better word for it is a microflux resistor, that capacitates the nuron acids hitting the regenerative receiver that amplifies the regenerative to work as a Raster Superheterodyne.
Pete
ORIGINAL: HighPlains
Glad I still have a 27 MC tube transmitter and regenerative receiver in case that newfangled superheterodyne doesn't work.
Pete
#115
MO
I don't get why are people making such a big deal out of this? 2.4 works so does 72 so just pick what you are comfortable with, why the need to prove one system is "better" than another. Since the "better" is different in each case.
#116
my dad is bigger and stronger than your dad...<wipes nose.="" from="" snot=""></wipes>
2.4 has more than sufficient range to allow safe operation of a radio control aircraft. People fly UAVS with the stuff and they fly well beyond 3000m (yes thats 9000ft)
2.4 is not used by cell phones, its used by Wifi, bluetooth and other peripherals.
the band our new rc equipment operates on is not the issue, its the implementation of the hardware. All computers have "moments" and our Tx are not immune. There in lies the rub. The 2.4 band is merely a wavelength of light, how TF can it be faulty??! This arguement is stupid.
"i used to work for XYZ blah blah blah"
I used to work for a military contractor and designed devices that required remote activation from a long way away. Hey we used the 2.4 band and many other bands and guess what?! They all frigging worked. The only time it stopped working is when either the hardware or software "had a moment".
FFS get over yourselves.
"Brand X and Y and Z and A and B also ahd issues this year..."
Heck how moronic is that arguement. Anyone can have an issue any time. What was the root causesof those "incidents?" Don't know huh?
More people have issues they can't explain and suddenly its the wavelienght of light thats at fault. Well lads unless the sun sent out more neutrino's 8min ago I can't see that only 2.4 is going to be affected.
Hardware/software, hardware/software.
PS not direct at you Ken
#117
You started it ;<
ORIGINAL: cloudancer03
lol.yeah it does remind me of kindergarten days.I dont let things like this get to me...I got shot down more than a few times using my old 72..,the 2.4 is a vast improvement and whatever the issue I am sure it will be addressed.I dont see us going back to edsels and model T fords either.
#118
As was implied in a recent Big Bang Theory most real engineers do not have doctorates - those are for people who can't design but want to teach ;<
And the "widespread use" only shows that people can be persuaded to do almost anything not that something is good. (I thought about straying off into our current political situation but then I decided it was off topic.)
An engineer with a Masters and part of a second
ORIGINAL: jester_s1
When I see an independent study done by a group led by someone with at least a Master's degree in electronics or electrical engineering (preferably a doctorate) that shows a flaw in the 2.4 technology, I'll believe it. Some guy Googling a few pieces of information and drawing big conclusions based on logical fallacies (the article) isn't worth the time it took to read it. Read some real research or don't read anything! Sure, our radios are not 100% reliable. They never have been. But the widespread use of 2.4 has shown that it does work and does have some advantages that 72mhz cannot provide.
#119
ORIGINAL: rgburrill
As was implied in a recent Big Bang Theory most real engineers do not have doctorates - those are for people who can't design but want to teach ;<)
BS/MS - Geology/Geochemistry
It felt like science to me!! [&:]
#120
I was amazed at the ability of 2.4 when I heard about that mass fly event with like 80 ? electric t-28s up together. The video was amazing.
There are no guarantees in this sport, whatever the future brings I hope it is safer/better without displacing ANY systems we have now.
#121
I really don't understand what the "problem" with 72 MHz is. Use PCM with fail-safe and get a switchable frequency module so you don't have to wait for a pin. The only reason I see to go to 2.4GHz is that so many cheap models are available.
Actually, so many of you have gone to 2.4GHz that I am just fine on channel 47.
Bob Burrill
Bob Burrill
#122
The other advantages of 2.4 in my view are:
Smaller more vibration resistant receivers
Far less prone to conventional RF interference (metal to metal, ignition, etc.)
ZERO chance of being shot down (it has happened to me twice - on 50MHz ham band BOTH times)
#123
#124
Then I pretty much give up. Your refusal or inability to accept or understand the Rule as written is not make anything i have written wrong.
I know that the FCC will not require a broacast station to shut down for this, not sure about remote cranes, I would think they may have to follow the same rule depending on which band they are on. But to say that we cannot do anything about a broadcast station bleeding into our channels is wrong. I know that they havemade them retune their transmitters to stop interference before. Sorry if I make you angry not to take your word for this.
#125
ORIGINAL: KenP
The AMA won't be able to make them get off of 2.4 anyway unless they ban it at competitions. The article is proposing additional frequencies. I really don't see why we should be upset with yet another option.
