ama and cookies
RE: ama and cookies
Try checking your security settings. You have to allow some cookies to be allowed to have a full account and you must be an AMA member. Anyone can view the website.
Computer literates will probably provide a much better answer.
RE: ama and cookies
Man, as I said I was hoping some computer literate would fix things for you. I can discuss AMA with the best, however this computer stuff is way over my head.
Try this: email Joyce Hager @ AMA -- [email protected] -- or better still call her at (800) 435-9262 ext. 200, and tell her in detail just what your problem is. If anyone can help you with AMA problems, she can.
OTOH, Scott Tuttle at extension 244 (same 800#) or [email protected] just may be the answer man. He is in charge of website problems.
Good luck.
Good luck.
My Feedback: (21)
NY
RE: ama and cookies
Did you add both http://modelaircraft.org and https://www.modelaircraft.org to your trusted sites?
Add them 2 times each, one with checked server verification and one without.
Also run Windows Update and install everything recommended ... less hardware.
Did you try in Firefox?
