what is te faa up to, rules for us?
#176
RE: what is te faa up to, rules for us?
ORIGINAL: Sport_Pilot
I have talked with them and at any rate don't seem be talking the same subject. From your case that you didn't bother to read.
huu (a sigh), this gets complicated. Does anybody know if they get a waiver from the FAA for the Reno races? I am wondering how they can legally hold them? They maybe in non navigable airspace ( or do they) but aparently that is only good for the ultra lights, cause Silent says we cant fly models without FAA's approval because we fly in their airspace. However they hold pilot certificates and they are obviously flying too close to other aircraft and other violations.
they probably get the same wavers that any airshow gets ,
aerobatic pilots nead altitude waivers to operate down to the deck
And again, they do not agree with you.
By holding a pilot certificate issued by the FAA, Hill submitted to the FAA's jurisdiction regarding any operation of aircraft under that certificate that may affect safety in air commerce. When, as here, the pilot has operated an aircraft in a careless or reckless manner that may be deemed inherently dangerous, see Haines, 449 F.2d at 1076, such conduct potentially affects air safety. The FAA clearly has jurisdiction to take appropriate action to deter future unsafe conduct by Hill or other certificate holders if it determines that safety in air commerce requires such action.
#177
ORIGINAL: Silent-AV8R
I never said you need FAA approval. I said they have jurisdiction. But in the end they will be granting approval, even for your park flyer within the framework of the new SFARs. I like the language of regulating by not regulating that they use. What they are doing is defining what a model airplane is and how it can be operated and saying if you do so, then you are exempt from all the other regs in the new SFAR. Which is so odd, since Sport Pilot has made it clear that they have no jurisdiction outside of navigable airspace, yet the FAA seems determined to pretend that they do.
Go figure.
Go figure.
Ok, where are the ARC recommendations for the other UAV's not sUAV's and models? Because I don't want your opinion, I want facts.
#178
Go figure.that guy in Florida riding in a lawn chair with balloons got his *** in a wringer , the faa hammered him
#179
My Feedback: (21)
My comment about the usual suspects is in reference to the AMA haters who reqularly respond in this forum. I appreciate someone who has consistently tried to change what he perceives as problems with the AMA executive council. I have belonged to the AMA for almost forty years and have been a leader member almost that long. I don't have the same feelings about the EC that you have, probably because I have never had much dealings with them. As a club officer I do have to interact with the AMA more than most members, almost always I have been received in a friendly, competant manner. This is not to say that I agree with AMA policies 100%, but in the case of the current discussion I really don't see what the problem with the AMA's stance is. It is only common sense that the AMA would try to have a say in the FAA rules and regs that concern model aircraft and that the AMA safety guidelines would be used in order to promote safe flying. Being a club officer in a moderately sized club, 70 to 100 members, I have had to deal with the "no one can tell me what to do" element many times. My fear is that an "outlaw" flyer will do something stupid to get the FAA or Dept of Homeland Security on our necks and god help us if that happens. From what I read in the FAA focus group recommendations most of the groups concerns are covered in AMA's safety guidelines. I don't agree with the turbine restriction but can understand that if you have no knowledge and see the videos regularly posted on YouTube showing turbine crashes someone could come to the conclusion that turbines are extremely dangerous. This is were an organization like the AMA can help educate people and dispell some mistaken conceptions.
Larry
Larry
#180
http://www.faa.gov/aircraft/air_cert...ovals/uas/reg/
The Interim Guidance document covers the whole spectrum of UAVs. The ARC deals with the small ones and how they will fit into the larger framework.
http://www.faa.gov/aircraft/air_cert...dance08-01.pdf
Funny, you post endless posts comprised of nothing but your opinions, and then demand that others use a different standard. How ironic is that?
#181
//SNIP//
//SNIP//
I don't know just how much you have worked with / for / or whatever the FAA in your lifetime, however in my lifetime, or at least 41 years, and especially in the last 28 of those years, I became very opinionated that as I said early in this thread, They do not operate by any standard, and have all the power of the Federal Government behind them. While I have stood up and been counted many times, even I know to step out of the way of a Tiger/Panther tank. (Translated to: no matter how poorly the machine is built and may require extreme maintenance, but when it is so very large and can do extreme bodily injury, I know when to jump. )
As an airline pilot, I knew to eat no 'burgers with poppy seed buns as they could give a positive drug test in those no-notice tests. If an airline pilot received any positive on a test, then the FAA grounded him/her for ONE FULL YEAR regardless of any information that may prove the test wrong. NO RECOURSE.
While I knew the applicable FAA regs. better than most pilots, I also knew to never push that envelope as an FAA person could, would, and DID create significant hardships using their powers. Preach regs. and details all you want. It can very well cost you a lot of Yankee $$$.
#182
Larry,
Good post, but I'm afraid your statements are entirely too level headed and reasonable to be included in this forum.
#183
ORIGINAL: Hossfly
#184
ORIGINAL: Hossfly
Is that not a bit presumptous, SP? In posts 151, 154, 158, 159, and especially 160 (#s at this time) YOU use the term, "I think..." for a number of your OPINIONS !!!
//SNIP//
//SNIP//
You are right Hossfly, a lot of decisions seem to fly in the face of fact, and that would lead many to think the FAA is all powerfull. But they lose some too. Especially in my field with property rights issues. They have more lee way with air safety issues, because, well no one wants to be accused of being against air safety. And yes I do use the term I think and I don't intend to say that my opinion is the final word. Silent may well be right is at least some of what he says. But I don't see the point of argueing the same thing over and over so now for some facts. I think the ARC recomendations for other than models were stripped from the prior postings. However I have found others, and it does seem to say my example would be illegal. And I guess it may be if adopted as written, but I am not so sure it should be. Seems to me it should be allowed for at least some very small autonomous aircraft. That is without FAA certification.
#185
Larry Walters flew to 16,000 feet and over Long beach airport. So he should have gotten in the trouble he was in.
http://en.wikipedia.org/wiki/Lawn_Chair_Larry
#186
Bout those Reno racers. Do they get a waiver? Because if not the reason why could be useful.
#187
#188
Trans says Navigable is above minimum alts,
they told FAA to set those minimum alts,
FAA did, and per 91.119c the min alt may be the deck when applicable,
making above the deck 'navigable' in those cases (part c of 91.119)
#189
The land at the end of their runway is navigable airspace and yep the FAA has jurisdiction as you found out. Now if you were a few miles from the end of the runway, or possibly a thousand yards to the left or right (not sure of the distance) then no they don't have jurisdiction of the airspace. As I said I have worked with an airport trying to prevent a tall building from being built in its extended pattern, the FAA could not help, but if it had been at the end of the runway for miles out it would have been a different story. However there are limits to the height of construction and I think you could have built a house if you were the proper distance from the end of the runway. You must have been in their ACUIZ aera where no structure above the ground is allowed at all.
i went threw this with a glider club in 85 i owned land at the end of there strip i tried to sell it to them , they were not interested .
so i decided to build a spec house on the property . i got as far as to put in the foundation when i was served with an injunction to stop work immediately . the case ended up in the Dickson fed building in Chicago, i lost!! the faa did have control of the airspace from the ground up , rather than pushing the issue further i came to an agreement with the glider club to purchase my twenty five acres
Darwin N. Barrie
AMA`12192
Professional Pilot
fixed wing, rotor wing, Commercial/Instrument in both
#190
Sport, as you have been for many threads, YOU ARE WRONG AGAIN!!!! If you really believe the FAA does not have jurisdiction over ALL airspace, you are sadly mistaken.
I think maybe you are hung up on jurisdiction? That term is not absolute, as the FAA does have stake in some instances. But generally you have the air rights up to 500 feet.
#191
well if for some reason you can successfully claim the faa has no controlling legal authority, they can revert to the commerce clause which will give it to them
#192
Model airplanes have gotten to large, and model airplane pilots have gotten to bold.
And this is a non-bias view. I love modeling but love staying alive more.
Charles
55 years of modeling.
Past professional pilot.
Commercial/Commercial Seaplane
Charles
#193
ORIGINAL: Avaiojet
Charles
Charles
#194
NY
I dunno but I think there is another wrinkle to be considered and that is,neither the FAA, congress or anyone else in Gov't is going to allow an entire industry to dry up with all those jobs/taxes lost as a result of it, not to mention the fact that the retailers/ wholesalers, AMA as well as the end consumers and anybody else concerned is going to scream bloody murder, they may indeed place some rubber stamp rules in typical uninformed dislocated fashion on certain stuff to address certain instances that may have arisen but ANY GOVERNMENT AGENCY no matter what the initials are is going to be 10000% about the revenue and they are more than anything probing our defenses for a way to yet again drive their hands in our pockets and assign yet another FEE to our already critically limited and UNTAXED freedoms
whats any more frowned upon or dangerous than booze and smokes which kill monumentally more people annually than anything whatsover involved with an rc aircraft but I certainly don't see any indication of big brother banning them but rather they continue to raise the tax on them yet another example of GOV'T saying by example OK so you want to kill yourself with booze and cigs it's ok so long as you pay till you bleed and pad big brothers pockets first.
I mean what is anybody thinking you can't even own a damned DOG without paying the town office $35 for the priviledge and you want a freebie on being able to fly an rc aircraft
BLASPHEMY LOL what the hell were we thinking, hell I'm waiting for the waste of Maine to tell me I need to register my rc boat and slap a $15 milfoil pond weed sticker on it.
#196
IL
I wouldnt say that to loud about the milweed they might hear youy and say thats a good idea! I think the goverment is just upset because there not getting enough money from us and they want control!
#197
MN
Well, for what it's worth, I'm gonna keep doing exactly what I do until someone forces me to stop. If I can't fly my planes, I'll sell themto some Canadian personand go back to helis like before and fly them in my front yard.
I'd like to know when they're gonna try to outlaw birds. Those big ones get up just as high as our best sailplanes and they're even more dangerous. Besides, birds are far more widespread and common than R/C planes.
If my right to fly my models gets taken away, you can bet abig stack of black chips that I'll be EXTREMELYUNHAPPIERwith the government, but there's little I can do at my age except look like "thedumb kid with the toy airplanes".
#198
You guys need to get a grasp on the reality here. First, the ARC summary is just a list of recommendations to the FAA. The FAA will now start up their sausage grinder (as Rich Hanson called it) rules machine and put the ARC summary in there along with all the FAA rules making rules and protocols and grind on it for likely at least a year. Then they will issue a NPRM and open up for public comment. THen they review the comments and either issue a final rule or start over (rare, but it does happen). So this is at least 18 to 24 months away from being anything.
Then, if the ARC is used much at all, then really nothing much changes for AMA members. SO all in all there is a reason to be watchful right now, but hardly a reason to panic.
Meanwhle I'm planning to fly all weekend in a contest. See ya'
#199
Just my opinion but when all of the manuvering is finished if ya want to fly a model you will belong to the AMA, pay whatever dues they deem nessesary for a license and that will be that. Not venting on the AMA or FAA at all, that is just the way I see it. I have modeled for over 45 years and this should slowly kill outdoor model flying for the average Joe. Take a look at general aviation and we see our future, not exactly bright but even dimmer without the AMA. Not exactly a red letter day for those who just love model aviation.
#200
NY
The bottom line is if we as a group do not make every effort possible to police ourselves and act collectively,we are inviting outside intervention from whatever agency thatmight be appointed todo what we have failed or refusedto do, at that point we will be paying to support that agencies activities.
Additionally organizations like the AMAare going to be you're only voice with the powers that be and should be supported as long as you want to continue to have a voice in the matter
politicians are not now or ever going to listen to complaints or concerns from a million differentINDIVIDUALSthey will only listen to one representive that is "recognized" as the agency or spokespersonthatthey feel best addresses/represents the concerns of the collective group.
Any individual attemptsto have a voice unless accompanied by a 20,000 signature petition are going to fall on deaf ears or wind up in the round file without even being read
if you are lucky and at most you may receive a generic form letter signed by somebodies secretary and thats as far as it will ever go justmy .02
