SUPER STUNTS 60 engine mount >
Old 07-31-2003 | 11:12 PM
Default SUPER STUNTS 60 engine mount
What engine mount do you use if you use an engine larger than what is called for?
Old 07-31-2003 | 11:33 PM
Volfy's Avatar
My Feedback: (23)
The WM stock engine mount can accomodate a pretty big engine if you let it spread as wide as the cowl cheeks would allow. IIRC, both a Magnum 1.08 2stroke and 1.20 4stroke sat on it no problem.
But if you do need a different mount, any of them would work fine. You'll just have to redrill holes and press in new T-nuts.
