GP Waco?
#251
RE: GP Waco?
Simple, a better, more scale looking ARF came out. Also the cost of the hobby, some are getting out. (see the reasons listed)
The Pica kits build to a better looking, with as much scale detail as you wish to add, plane. Detail can be added to an ARF, but it is as much work if not more than building the kit or from the plans.
The only thing Cox had in common with the Pica kit was the name. Cox redesigned the Waco and did not leave much untouched.
#252
RE: GP Waco?
ORIGINAL: frisco2022
Is anyone else using a DLE-20. I have a DLE-30 in a 12 pound Yak-55 and the thing is a rocket with greater than 1:1 ratio. I just cant see putting that in a 1930's era biplane. I know there is the throttle but what do you think?
The 20 looks like it has the power, but does it have enough thrust to over come the drag of this big biplane?
#253
RE: GP Waco?
Power doesn't actually fly the thing, Thrust does. Pick an engine that will swing a large diameter, low pitch prop. That eliminates high revving motors, or at least those that need to rev to get their power. Biplane drag is speed dependant, provided you don't want to go fast, then the drag, and therefore thrust requirement, will remain lowish. Pick the lightest model you can find, then you don't have to go fast to fly, and you can use your excess power (thrust) to do the other stuff biplanes (Read Waco's) love to do, big lazy eights, slow stall turns, chandelles, and the rest. If you build heavy, then you bring both ends of the flight envelope closer together, and the whole thing becomes much less fun.
Evan, WB #12.
Evan, WB #12.
#254
RE: GP Waco?
DLE 20 will be just fine. We have a guy at our field with a Great Planes Stearman with a DLE 20 and it flies great using a 17x6 prop. After watching it fly I have decided to go with the 20. I have a DLE 30 in my Aeroworks Cessna 195 and it is a rocket ship, way to fast even flying less than half throttle. It has a 90" wingspan. I would go with a rear carb setup.The DLE 30 on my Cessna has a side carb and does not run well at the lower power settings. Will be converting it to a rear carb soon. I guess that is one reason they have changed to the rear carb setup. Hopefully it will help it run smoother.
#256
RE: GP Waco?
Maybe back when this model was designed, the DLE 20 was not available. It was introduced after the 30. Most people want to over power their models anyway. I guess that is what the throttle is for. I believe if you want scale flying, the 20 is adequate. The manual even suggest a 120 four stroke (20cc) for this plane as an option.
#257
My Feedback: (60)
AZ
RE: GP Waco?
ORIGINAL: Stickbuilder
On top of that, no one has the parts templates but the Brotherhood, and we have the rights to them reserved, so that avenue is a dead end as well.
#258
RE: GP Waco?
I do hope the 20 proves to be adaquate for spirited flight, I want a little more than to just lumber around. It would certainly make for a cleaner install!
#260
RE: GP Waco?
ORIGINAL: Chad Veich
You don't think anyone outside of the ''Brotherhood'' has templates for the Pica Waco? Just looking for clarification, not sure I understand the statement.
Bill, Waco Brother #1
#261
RE: GP Waco?
Well being that we are talking about engines and speed. I am going the dle 30 route and know that a 18x8 will be to fast but what about a 19x7 or 19x6. What pitch is going to be best.
#262
RE: GP Waco?
Look at it like its the transmission in your car. Running an 18-6 is like leaving your car in second gear. It does not go real fast, but it will accelerate like a bandit. That's what you are after, the pulling power of a low pitch prop. Dan Hudson has an 18-5 for is Waco, and its just about perfect. That is a hard prop to find though.
#263
MN
RE: GP Waco?
Wow....Sounds like most are beating a Dead Horse...???
GP Waacooo doesn't have anything in common with the Pica/cox ,, well other than the name YMF Waco...
Possibly start a post that talks about all the diff. between each other ect ect...
Someone should post a build page. This would be helpfull and nice to see...
#265
NC
RE: GP Waco?
ORIGINAL: kochj
#268
My Feedback: (36)
RE: GP Waco?
Wow!!!! I knew the DLE 20 would fit good in the Waco ..... I know this will have enough power to be "spirited" as someone has called it. I'm not worried after I have seen some 20's pulling 14# airplanes vertical for more than I will do with my Waco. I'll post more pic's soon.
MN
RE: GP Waco?
The 20cc makes the engine cowl look larger than the os 1.20 4-stroke does. (the video hobbico posted, and in instructions)
Perhaps do to mounting the 4-stroke sideways and the 2-stroke inverted..??
#271
RE: GP Waco?
There are several bulld pages in the Waco YMF thread. You are not going to be building anything with an ARF. (Sorry, I had to say that), but it was built by someone in China, or Vietnam). You are putting subassemblies together. To claim that you are building it is an insult to those who are cutting all their parts, and are actually building the model. I'm sure that you didn't mean it that way, but put yourself in the shoes of the guy who is doing it all.
#272
RE: GP Waco?
You guys who chastise about builds or arf's .....I get what your saying about building, but think you are being a little critical An arf is like a partial build, So what!
#273
RE: GP Waco?
In actuality you are assembling an ARF not building it. As they say whatever makes your tree bark, if it works for you then it is good. Not bashing, just stating the obvious.
Skipb
Skipb
#275
My Feedback: (45)
RE: GP Waco?
