Reload this Page >
GP Waco?
GP Waco?
Old 07-25-2011, 09:32 AM
  #801
Hill202
My Feedback: (24)
Hill202's Avatar
Default RE: GP Waco?
Looks good Husabearg! Glad to hear that it flies so well.
Old 07-25-2011, 09:40 AM
  #802
HUSABEARG
When my son flew it it went left so hard that it fley right over our pit area.
It got a little scray at first like it was going to stall then he hit full power and it climb straght up like a 3d plane.
Verry cool.
Old 07-25-2011, 10:04 AM
  #803
mmn
Two flights yesterday. I noticed on the first flight it was acting a little squirrelly on the taxi out. Having some difficulty turning left (grass field). I attributed it to the 45 degree 6-8 mph crosswind and didn't think too much about it. Took off, nice flight, landed, taxied back. 2nd flight, same thing but managed to keep it pretty straight on take off. Another nice flight.
Later while I was taking it apart for the trip home I found the tail wheel was missing. It was laying out on the startup bench! lol
VERY forgiving airplane...
Regards
Michael
Old 07-25-2011, 03:18 PM
  #804
Pilot P51
Well here is mine , ready for the test flight. I went with the Saito 125 I had in the hanger. It is swinging a 15 x 8 prop getting 9000 RPM's. It should pull it very good. It balanced right on the money at 5 1/4". With this engine I did not have to cut the cowl it fits right over it. I also added a glow sytem so I would not have to cut the cowl on start ups. I hope to get her in the air later this week if the wind calms down.[>:]
Walt
ID:	1639983   Click image for larger version
ID:	1639984   Click image for larger version
ID:	1639985   Click image for larger version
Old 07-25-2011, 03:35 PM
  #805
Hill202
My Feedback: (24)
Hill202's Avatar
Looks great Pilot P51. It's nice to see the variety of engines being used on this plane.
Old 07-25-2011, 06:08 PM
  #806
SkyPilot101
What size is the tank (17oz?) how's the flight time with the Saito 125? The FS sound on the Waco will be hard to beat!
Old 07-25-2011, 07:14 PM
  #807
Pa-18cub150
Pa-18cub150's Avatar
Hi Pilot p51
How did it balance with the Saito 125? Any weight added ?
I’m am interested in your flight results .
Old 07-26-2011, 06:02 AM
  #808
Hill202
My Feedback: (24)
Hill202's Avatar
Has anyone put smoke on this yet?
Old 07-26-2011, 06:52 AM
  #809
Pilot P51
NO weight was needed. It balanced out perfect at 5 1/4" which is were the CG is located. I hope to get it in the air this week if the winds calm down.
Walt
Old 07-26-2011, 07:53 PM
  #810
cannonball200
My Feedback: (36)
cannonball200's Avatar
I finally got time to glue the combing around the cockpits. Also, I drew the outlines around the door & storage compartment and used the handle's decals and the hinge's decals that came with the kit. If it ever gets below 108* I will get it out and fly some more. Also finally got the new pilot in...
ID:	1640515   Click image for larger version
ID:	1640516   Click image for larger version
ID:	1640517   Click image for larger version
ID:	1640518   Click image for larger version
Old 07-28-2011, 10:33 AM
  #811
HUSABEARG
Looks good but what kind of pen did you use to draw the lines.
is it some kind of special ink?
Old 07-28-2011, 12:23 PM
  #812
leedees
leedees's Avatar
ORIGINAL: cannonball200
Cannonball, what size combing did you use? The detailing looks great!
Old 07-28-2011, 12:31 PM
  #813
Hill202
My Feedback: (24)
Hill202's Avatar
Did you guys that are using the DLE 30 beef up the firewall?
Old 07-28-2011, 12:50 PM
  #814
Pilot P51
You and use any fine point black permanent maker. Then spray a light coat of Clear Enamel over the lines. I use this on all my decals I make and never have a problem with the colors fading.
Also you can order the Top Flite panel Pen. L5HX4503 Top Flite Panel Line Pen
Leedees - Used 1/4" combing on my plane.
Walt
Old 07-28-2011, 02:16 PM
  #815
cannonball200
My Feedback: (36)
Sorry, I was out for a while.. I used a Sharpie permanent marker extra fine black. Right on with the rubber windshield washer hose 1/4 ". I had some small sharp pointed sissors I slid into the hose and split it . I glued it on with white canopy glue. I have not sprayed any clear enamel or sealer over the panel lines.
Old 07-29-2011, 03:21 AM
  #816
mmn
Sorry, I was out for a while.. I used a Sharpie permanent marker extra fine black. Right on with the rubber windshield washer hose 1/4 ''. I had some small sharp pointed sissors I slid into the hose and split it . I glued it on with white canopy glue. I have not sprayed any clear enamel or sealer over the panel lines.
1/4" drip line tubing works good too. Home Depot where the sprinkler stuff is.
Regards
Michael
Old 07-29-2011, 03:57 AM
  #817
vasek
vasek's Avatar
Michael, you let a bimb0 blond with big b00bs fly your Waco????? [X(]
Old 07-29-2011, 04:16 AM
  #818
cannonball200
My Feedback: (36)
Looks like the drip line tubing might even look better....
Eddie
Old 07-29-2011, 05:17 AM
  #819
mmn
ORIGINAL: vasek
Yep. One of my flying buddies said the reason she wears sunglasses is because she has black eyes from flying inverted... lol
After a flight the other day I noticed she had fallen over. She didn't fall out even while flying inverted. She was kind of wedged under the dash. Guess what was holding here in?
Regards
Michael
Old 07-29-2011, 08:14 AM
  #820
Hill202
My Feedback: (24)
Hill202's Avatar
This is your fault Skillet
Old 07-29-2011, 08:55 AM
  #821
cannonball200
My Feedback: (36)
Wow Hill202 & Skillet,,,,,,, I guess you guy's will out run me to 500'...........Just wait on me though, because I will get there, just a little slower with the DLE 20.
Eddie
Old 07-29-2011, 10:47 AM
  #822
skillet92
Hey hill sorry about the delay in pics I have had wifey van troubles and it has been a long one. I will get them posted tonight. And btw . And cannon it does get there quick.
Old 07-29-2011, 02:25 PM
  #823
Hill202
My Feedback: (24)
Hill202's Avatar
I guess nobody has smoke on theirs. I'll have to blaze that trail.[8D]
Old 07-29-2011, 06:56 PM
  #824
skillet92
I have thought about smoke and still might do it. It would look cool on this plane! Here are some pics of my engine setup and muffler.
ID:	1641790   Click image for larger version
ID:	1641791   Click image for larger version
Old 07-29-2011, 07:06 PM
  #825
skillet92
And some more!
ID:	1641793   Click image for larger version
ID:	1641794   Click image for larger version
