Thunder Tiger Pegasus Trainer ????
bigbri;
Got one assembled, waiting on weather to launch it. Have an OS46fs mounted. Had to go to a 10x6 propbecause of ground clearance. The kit assembles easily, everythig fit. The fuel tank is very tight to get in, as the instructions say(a little vaseline might have helped). One of the foam wheels was out of round, don't like them anyway, replaced with low bounce DB from local LHS. Also replaced the nyrod for the elevator & rudder with a 2mm rod, as during assembly one clevis threaded rod just pulled out when checking servo set up. The dowel rods for the wing hold down are tight, may need a little sanding. Much better kit than the world model 40, I crashed. Now to fly, This weehend is forcasted ok.
Will let you know.
Will let you know.
bigbbri;
Forgot: the cg came out right on, at 3.5 from LE and lateral took a penny on the left wing. Added a coupla' 4" diagonal strips of red and clear checkered monocote to underside of left wing and shifted battery pack, lateral now right on.
Good Luck'
Tigerpaw
Good Luck'
Tigerpaw
