Engine recomendation >
Old 12-10-2002 | 04:20 PM
Default Engine recomendation
I just purchased a Hanger 9 Ultra Stick 40 and would like a recomendation on as engine to use. I am a fairly new flyer and have been flying a Goldberg Tiger 2 with a Super Tiger GS 45. I want to start using 4-strokes now. The box says a Saito 56 works well but also says you can go up to a Saito 72. I plan to build the plane using the optinal flaperon set-up... I don't know if this would require more power. Also I've heard some bad things about using the supplied CA hinges...Does anyone have an opinion on this?
Old 12-10-2002 | 09:23 PM
daveopam's Avatar
My Feedback: (9)
Go with the .72. You can always pull back if its to much power. Besides that it will be around longer than
the Ultra Stick , and you have a bigger range of planes to put it on. I don't know what hindges come with that
kit , but I use CA hinges with little problems. The key is getting your slots the right thickness and making them
parrallel on the center of the hinge line. later daveo
Old 12-13-2002 | 06:22 PM
daveo is right about the engine. On the CA hinges, I've never seen them fail on the 40 sized one. Just for peace of mind though, you can spend 5 bucks at your hobby shop and get some ones you know will work.
