wing mounting on Superstick 40??? >
Old 08-08-2003 | 07:37 PM
My Feedback: (28)
Default wing mounting on Superstick 40???
How do I mount the wing on the Hangar 9 superstick 40? Are the mounting bolts nylon or metal? Any tips?
Old 08-09-2003 | 03:58 PM
My Feedback: (18)
I recall there being 4 4mm bolts on that model... You can easily change them to 1/4-20 nylon...
Old 08-09-2003 | 07:54 PM
Oregon Craig's Avatar
Here is the entire manual, it should tell you. I didn't check.
http://horizon.hobbyshopnow.com/shar...700-manual.pdf
Old 08-11-2003 | 07:32 PM
Ernie Misner's Avatar
Greetings, I used the stock metal bolts that came with the kit. (metric, 4mm?) They worked just fine, 2 in the front and 2 in the back.
Are you just assembling that arf??? The balance point shown in the plans is too far nose heavy. It should be back about 1/4 inch from what is shown.
Good luck, write if you want,
Ernie Misner ([email protected])
