Reload this Page >
Need Canpoy
Need Canpoy
Old 03-28-2011, 10:55 AM
heistheman
Default Need Canpoy
Ipurchased what Iwas told was a CMP (China Model Products Yak) it has a wing span of 72" Iset the hatch and canopy behind my BBQ grill in the garage, cooked some steaks and melted the canpoy beyond repair. Any Ideas on replacement. How can I tell if this model is truly a CMP YAK?
Cliff
Old 03-28-2011, 11:31 AM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Default RE: Need Canpoy
Can you post a pic? I am aware of a couple of 72" Yaks on the market that are relatively inexpensive and originate from China. I was just thinking about this in the shower; I have a 69" Yak that I'd like a new cowl for.[&:]
Old 03-28-2011, 02:54 PM
opjose
opjose's Avatar
Don't throw away the melted canopy.
At worst you can cut out the melted or deformed parts... if you cannot find a replacement.
Then put wax paper under it, and inflate a balloon to give you are rough shape of the missing area.
Finally epoxy fiberglass strips to fill things in, sand and paint.
You'll loose the transparancy, but you can paint the transparent areas a dark color.
Done correctly it will look as good as new, minus the clear covering, and it will be far stronger.
Old 03-28-2011, 05:04 PM
jzrf6c
Several outfits make fiberglass replacements. Try searching for fiberglass specialities. If they don't have exactly what you want you can call them and they will help. I've just given them the dimensions of what I want and they provided a cowl that fit great.
Old 03-28-2011, 06:15 PM
heistheman
Thanks I'll check it out
Old 03-28-2011, 06:18 PM
heistheman
Great Idea using the old one about 2/3 of it is still good.
Old 03-29-2011, 11:38 AM
red head
Sig still has some canopies listed, you might want to check them out. They are USA and can probably use some more bussiness , seeing they have NEW owners. ENJOY !!! RED
