HANGAR 9 1/4 SCALE J-3 ARF-IS THERE A LEFT AND RIGHT AILERON????
I have assembled my Hangar 9 1/4 scale J-3 ARF and both ailerons do not match the wing at the inboard and outboard junction. The ailerons appeared to be symetrical and the instructions do not say there is a left and right aileron nor do they advise that there is a difference. However, I suspect there is and with a 50/50 chance I installed them wrong. Just curious if anyone knows the answer?? I am about to cut the ailerons off and swap them. Any body??
RE: HANGAR 9 1/4 SCALE J-3 ARF-IS THERE A LEFT AND RIGHT AILERON????
On mine if i match the inboard the outer aileron is up about a 1/16th of an inch up. Hope that helps.
Here are the instructions in the assembly manual for attaching the ailerons to the wings:"Repeat Steps 1 through 8, and using five hinges per
aileron, hinge the ailerons to the wing panels."
The ailerons appear to be similar and symetrical when held against each other(as the horiz stab, elev). However, there is a very slight difference in the left and right aileron. They CAN be mounted to the wrong wing. After removing the ailerons and hinges and reinstalling on opposite wings, the ailerons match perfectly. It would be nice if the manual just mentioned that the ailerons, though not labeled, are different.[][]
ORIGINAL: Lifer
As I recall, there was a hard-point on the bottom of each aileron. That should settle the issue of which aileron goes on which side.
