 seagull cub 120 >
seagull cub 120
seagull cub 120
Old 01-08-2012 | 07:32 AM
michael wood's Avatar
Default seagull cub 120
has anbody mounted a gas enging on this airplane ? I am mounting a rgc 20cc on it and i need to know if it would be alright to mount the ignition box to to firewall behind the cylinder head. Ive looked around rcu and havent found alot about it i see the ignition box mounted to a engine box but not the fire wall. so any help would be nice thanks michael
Old 01-10-2012 | 04:45 PM
Default RE: seagull cub 120
I have heard of no hard rules regarding mounting an ignition unit other than be careful to protect the high voltage wire from chaff and keep it away from any metal throttle linkage that might be running back to receiver electronics.
Old 01-10-2012 | 09:27 PM
got it mounted to the fire wall using eye hooks and rubber bands and fome pad but i think i might have an eye hook touching the box i will have to see michael
Old 01-12-2012 | 01:19 PM
My Feedback: (7)
The only issue I can think of with mounting it on the firewall is to be sure there is adequate cooling. Cooking the ignition is not a good thing. Cubs don't usually have large firewalls, you may need to consider mounting the ignition behind the firewall with an opening to allow the plug cord to come through to the spark plug. I did that type installation on a Chipmunk, and it was a happy solution. I provided foam padding for it to minimize vibration.
Old 01-12-2012 | 09:53 PM
cant mount it behind the fire wall unless i make a hatch
Old 11-12-2012 | 05:43 PM
I have this plane with a rcg 26cc. I made a hatch on the bottom and mounted the ignition in there behind the firewall. This a great plane and engine combo. Does huge loops and nice hammerheads.
<br type="_moz" />
