Engine-plane compatibility question please:
My Feedback: (139)
FL
Hi there, i have a brand new OS 108 FSR that will like to use if possible on a world models ultimate bipe arf 120R, and im not sure if it will be enough of not? If it will be overpowered or underpowered, so im submiting both items specs and will apreciate any advice.
I dont know how to interpret and translate very well the engine specs or requierements.
World models ultimate bipe arf 120r:
Specifications
Wing Span : 53.5 in / 1360 mm
Wing Area : 989 sq in / 63.8 sq dm
Flying Weight : 9.9 lbs / 4480 g
Fuselage Length : 56 in / 1400 mm
Engine Required : 4 stroke 1.20 engine
Radio Required : 4 channel radio w/ 5 servos
OS 108FSR:
SPECIFICATIONS:
Engine Type: 2-Stroke
Displacement: 1.080 cu. in.
Cylinders: 1
General Specs:
- 1 cylinder
- Displacement: 1.080 cubic inches
- Bore: 1.140 (in.)
- Stroke In: 1.060 (in.)
- Shaft: 3/8 x 24 threads
- Low RPM: 2000
- High RPM: 16000
- 3.000 bhp @ 16000 RPM
- Weight (no muffler): 26.50 oz.
Applications:
- Giant
Street Price:
$249.99
WILL THIS PLANE AND ENGINE BE ENOUGH FOR EACH OTHER?
Specifications
OS 108FSR:
SPECIFICATIONS:
Cylinders: 1
General Specs:
- 1 cylinder
- Bore: 1.140 (in.)
- Low RPM: 2000
- High RPM: 16000
Applications:
- Giant
Street Price:
$249.99
My Feedback: (139)
FL
Could i add a sullivan smoke pump with a pits muffler and obviously the smoke fluid tank? Engine will still be enough to pull the extra weight?
Thanks.
Thanks.
The WM 1.20R is rated for a 1.20 FOUR STROKER....
So your 1.08 two stroke engine should outperform the stock configuration by a good amount once properly prop'd.
The 1.08 engine is roughtly the equivalent of a 1.4-1.6 four stroke engine in terms of power.
ORIGINAL: Turqui
Thanks.
Thanks.
Keep your smoke usage on the "light" side ( it is MUCH more dramatic to kick it in on occasion ).
Because you are using a two stroke the engine will rev higher and hotter than a four stroke engine, so using a smoke pump will be less problematic.
My Feedback: (29)
I once had a Dave Patrick Ultimate with an OS 108 in it and it did just fine. Run a Slimline pitts muffler. I would however suggest not adding ANY extra weight. I don't remember what mine weighed but Ido remember that anything more and the 108 just wouldn't cut it. I ran a 2 servo setup for the ailerons and linked the upper and lower ailerons with a pushrod. Worked just fine and eliminated 6 oz. Use an APC 15X8 prop.
