Dave Patrick Extra 330 1.2 ARF
My Feedback: (26)
I'm trying to obtain an instruction manual for this plane. I need the instructions on setting up the CG and contol rates. Since DP is no longer in business they have no website and doing a google search provides little information.
My Feedback: (31)
its the same as the low rate settings as a starting point and then adjust for your needs as some things change with CG of course. I maiden my extra at 5.25 and later moved it back to 5.75 and i really like the way it flew with that setting inverted it just required a very slight push.
Man, where are you guys finding these DPs? I thought they were long gone. The last ones I saw fly had a Saito 1.50 and an early DL50. The Saito powered plane would fly well, but was somewhat limited on 3d type maneuvers. The 50cc one ripped through the sky and was terrribly overpowered without serious throttle control. Good luck.
