 Eflite T-34 RTF power plant, Too much? >
Old 06-23-2012 | 05:45 PM
Default Eflite T-34 RTF power plant, Too much?
Would a Magnum 4 stroke .52 be too much power for this plane? It's a 25-35 sized electric plane, when someone adds more power its usually a 35 size electric. The engine can fit inside the cowl without modifications, which is why I am asking. The stock prop is a 12X6, which is the same prop the Magum calls for. Ihaventweighed it yet, but the OS weighed in at the same weight as the motor, ESC and battery pack, to the nose balance wouldnt change.
