Reload this Page >
New Hangar 9 1/4 Scale P 18 Super Cub
Old 05-25-2013, 04:42 AM
  #801
Fly RC174
Default RE: New Hangar 9 1/4 Scale P 18 Super Cub
Thanks Bikerbc,
I assume you are talking about the light kit that they recommend in the assemble manual, as mine did not come with a light kit.
I suppose that I could use a servo operated micro or system switch to turn on the light system with one channel, and then use a seperate channel to switch on the landing lights.
On the subject of the bungee cord in place of the rubber bands. I picked up a package of the mini bungee cords with the metal hooks on the end. They are about 1/4" diaimeter and 9" long. I thought I would try and see if they would work.
Old 05-25-2013, 06:07 AM
  #802
bikerbc
Yes I guess I must have ordered the optional lite kit.. My memory is pretty bad , I am fighting my way back from a stroke , I don't see why the little bungee cords wouldn't work , good Idea ..!/8" is the size you want ..
Old 05-25-2013, 06:40 AM
  #803
mobyal
Where'd you find the bungee cords?
Old 05-25-2013, 06:47 AM
  #804
bikerbc
Google The shock cord...You will come up with many suppliers..
Old 05-25-2013, 07:02 AM
  #805
bikerbc
I just Google d 1/8" shock cord and it came up with tons of suppliers . A lot guys use it to replace their tent pole cords it seems..Make sure to Google 1/8'' or you will come up with bigger stuff ..
Old 05-25-2013, 12:27 PM
  #806
BarracudaHockey
BarracudaHockey's Avatar
I missed a great chance today
We went up to GA for a fly-in that a club up by Kings Bay was dedicating a new field and I knew I was doing a glider towing demo so I had the Pawnee in the trailer so I took the Super Cub out and put my SBach in....
Well a guy shows up and lands with a full scale Super Cub and hangs around and watches us fly models for a while.....that would have been a cool picture......
Old 05-26-2013, 08:39 PM
  #807
pldawg
Finally was able to maiden mine tonight. Windier than I wanted for a maiden but I did it anyway and it flew great! Flew two sets of batteries before it got too dark.
Old 05-27-2013, 04:17 PM
  #808
regalmat
What prop are you guys using with the Power 160 and 10s 5000?
Old 05-28-2013, 06:13 AM
  #809
hanko
So biker Bob claims that a friend of his had his firewall come loose after 5 or 6 flights, anyone else had this problem?
Old 05-28-2013, 06:47 AM
  #810
BarracudaHockey
Mine is about 10 flights this past weekend, no issues other than the tires are showing some wear already.
Old 05-28-2013, 07:08 AM
  #811
hanko
well i dont have to worry about tires, mines on floats, thanks.
Old 05-28-2013, 07:51 AM
  #812
BarracudaHockey
LOL mine will be soon!
Old 05-28-2013, 10:21 AM
  #813
hanko
FYI, set the rigging up as the plans show on the floats. My CG came out at 3.5 inches back from the leading edge, which is the rear limits. I have a DLE 35 Ra. 18X8 Zoar composite prop, the two reicevers and two A123's set right on the CG. That CG makes the elevator a little sensitive, but not dangerous. Flaps need some down elevator programed to compensate for the pitch up. Work on the rates you like and use some expo on the elevator. I maidened mine Last Saturday, 10 total flights, no issues at all except an igintion switch taking a sheet. My fist two landing were dead stick, but actually the best ones, Go figure. These values Im giving you are for floats, as Ive never put the gear on, have fun. Also my ignition and battery are next to the fuel tank. If you check the sea plane forum, I have a bunch of pics posted
Old 05-28-2013, 10:23 AM
  #814
hanko
one more thing, glass the bottoms of those ****ty, crappy,lousy H9 floats. I used them cause they do look ****
Old 05-28-2013, 12:10 PM
  #815
bikerbc
I glassed the bottom of mine too and it really stiffens them up , I hope that's enough . I would not mind paying more if the floats were well made.. They are way over priced now for quality but for looks they are worth it .. I think I would sooner have a quality set of floats that would stand up to a few knocks and not tear apart . If they fill up with water and you take off your C of G could shift to tail heavy and make the plane hard to fly..Hanger 9 must read these threads and know how unhappy we are with the floats .. They are such a good outfit I can't understand why they don't do something to improve the floats
Old 05-30-2013, 05:15 PM
  #816
GORCFLYR
My Feedback: (7)
MOBYAL - how is the power with the Eflite 110 on 8S?
Old 05-31-2013, 05:44 AM
  #817
mobyal
I'll let you know after the weekend. Test flight didn't come off yesterday because apparently some of the rubber bands on the gear slipped off and weakened the gear on one side, probably would have collapsed if I'd tried to taxi. Running the motor up tho I can't imagine there'll be any power problems and would guess that most flying will be done at less than half throttle with ample power for vertical.
Old 06-01-2013, 12:52 PM
  #818
Jeepindog
Jeepindog's Avatar
I got stand-offs from PSP Mfg to properly space my ASP 160FT. It totaled 1.75" to clear the cowl opening with the drive washer. Not quite done putting the whole rig together but it seems like it may need more weight up front, although I still need to permanently mount on-board glow plus the battery, and the receiver battery. Anyone find a better pilot? The dude that came with the kit is not 1/4 scale, and he's ugly as all get out!
Old 06-02-2013, 06:19 AM
  #819
bikerbc
I found a Buzz lightyear doll that is just the rite size..We had a Mall show and I was surprised how much of a hit he was...
Old 06-02-2013, 11:55 AM
  #820
SKYPILOT
My Feedback: (9)
Hey guys,
To the guys that have gone with the Saito 182 twin, and used "stand-offs" to mount the engine to the firewall, What length stand-off did you use??..
Old 06-06-2013, 12:16 PM
  #821
BarracudaHockey
Here's some photo's of mine...
ID:	1889367   Click image for larger version
ID:	1889368   Click image for larger version
ID:	1889369   Click image for larger version
ID:	1889370   Click image for larger version
ID:	1889371   Click image for larger version
ID:	1889372   Click image for larger version
Old 06-06-2013, 09:22 PM
  #822
Jeepindog
Jeepindog's Avatar
Looks good Andy. That pilot looks funny with the helmet and PFD on, though!
Old 06-07-2013, 04:02 AM
  #823
BarracudaHockey
If you've ever seen me fly you'd understand the helmet! The PFD is because he's going to by flying on floats shortly
ID:	1889556   Click image for larger version
ID:	1889557   Click image for larger version
ID:	1889558   Click image for larger version
ID:	1889559   Click image for larger version
ID:	1889560   Click image for larger version
ID:	1889561   Click image for larger version
Old 06-21-2013, 03:50 AM
  #824
fat frank
I just posted a thread about the SC before I caught this site.I just received mine and am going to mount an evolution 33GX in it. Problem is the wraparound muffler. Since the engine is lighter than the recommended Z26, cold I use longer standoffs and shift the cowl? This would move the cowl about 3/8 to 1/2 inch farther out.Will the plane still fly as well as long as it gets a good balance?Thanks in advance
Old 06-21-2013, 05:14 AM
  #825
BarracudaHockey
I don't see why not. You have some play with the cowl but not a lot though unless you want to figure out a way to extend the mounting blocks.
With the G26 the screws are about half way out on the blocks to get everything lined up.
Ready to get wet!!
