 Katana 29% New World Models??? >
Old 11-12-2012 | 09:52 AM
Default Katana 29% New World Models???
New World Models Katana 29%. Has anyone built this? If so, How did you set up your radio and engine compartment? From the rudder servo to the spinner. This ARF is made in China, the manual is horrible and this is the first ARF and gas plane I have bought. I am using a DA 50cc.
Brian
Old 11-25-2012 | 04:50 PM
Default RE: Katana 29% New World Models???
<span style="background-color: rgba(255, 255, 255, 0);">I have a Tai Ji 60 from TWM and the manual is just as bad. All I can suggest is to look at as many manuals from similar sized designs from other mfgs. and you should have enough info to build a good flying plane. The manual you have, if it is what I am looking at online, does have enough info to build the model if you work carefully.</span><div><span style="background-color: rgba(255, 255, 255, 0);">
</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">Good luck with your build!</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">
</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">..Joe L</span></div><div></div>
Old 12-05-2012 | 11:39 AM
Thanks Joe,
Do you think (1) 20.0 kg or 277.7 oz servo is strong enough for the rudder on this bird? I was thinking two but not sure.
