Reload this Page >
Hangar 9 60 size corsair arf
Old 05-11-2012, 04:50 AM
  #2476
w1nd6urfa
w1nd6urfa's Avatar
Default RE: Hits and Misses of H-9 Corsair
I'm almost done and getting ready for maiden this weekend, se here's a brief build log:
I reinforced the retract / wheel bay area by inserting a U-shaped wire behind the retract mount
ID:	1761479   Click image for larger version
Old 05-11-2012, 04:56 AM
  #2477
Dangaras
Dangaras's Avatar
What's the U shaped wire for?
Old 05-11-2012, 04:57 AM
  #2478
w1nd6urfa
w1nd6urfa's Avatar
I used the Top Flite Corsair 60 decal set which suits the tri-color paint scheme
ID:	1761481   Click image for larger version
ID:	1761482   Click image for larger version
Old 05-11-2012, 05:00 AM
  #2479
w1nd6urfa
w1nd6urfa's Avatar
Then did quite a bit of weathering
ID:	1761484   Click image for larger version
ID:	1761485   Click image for larger version
Old 05-11-2012, 05:06 AM
  #2480
w1nd6urfa
w1nd6urfa's Avatar
Dangaras
I've read about wing folds and experienced it myself on the H9 Hellcat three years ago. Since then on all my planes with rotating retracts (where the bottom spar is divided at the wheel bay area) I reinforce the retract area with extra wood, glassing and the U-shaped wire that effectively subtitutes the bottom spar in the area of the wing that supports the plane's weight, suffers G forces with up-elev and also gets the landing impacts.
I've done it on a couple of P-40s and haven't had any problem since.
Old 05-11-2012, 05:11 AM
  #2481
w1nd6urfa
w1nd6urfa's Avatar
Wow, crossed the 100th page mark!
Continuing, drew panel lines with pencil, silver pen and more washes and airbrushing
ID:	1761487   Click image for larger version
ID:	1761488   Click image for larger version
Old 05-11-2012, 05:12 AM
  #2482
Dangaras
Dangaras's Avatar
Very nice. Good luck on the maiden..
Old 05-11-2012, 05:13 AM
  #2483
w1nd6urfa
w1nd6urfa's Avatar
Made strut covers from 0.8mm alum sheet, slightly curved to hug the wing
ID:	1761490   Click image for larger version
Old 05-11-2012, 05:15 AM
  #2484
w1nd6urfa
w1nd6urfa's Avatar
Next was the dummy engine, painted base dark grey, then Model Master Metalizer Burnt Metal (the one that buff-shines) and then a wash with rust and oil stains
Old 05-11-2012, 05:19 AM
  #2485
w1nd6urfa
w1nd6urfa's Avatar
I also made an air duct for the Saito 100 to direct the air flow over the cylinder and keep it cool. Greek summer can get quite hot!
Its the first time I try this, will report on how it works
ID:	1761494   Click image for larger version
Old 05-11-2012, 05:23 AM
  #2486
w1nd6urfa
w1nd6urfa's Avatar
Post-maiden I will tackle the TF cockpit, and look for a suitable pilot. I got my eyes on [link=http://centuryjet.com/product_info.php/cPath/46_38_36_31/products_id/33]the CJ 1/9 pilot[/link], any opinions?
CG at 4.5" to start with, might move back if I notice any nose-over tendencies.
Old 05-11-2012, 05:42 AM
  #2487
w1nd6urfa
w1nd6urfa's Avatar
Also post-maiden I'm thinking of hiding the Rx switch behind a simple hatch like [link=http://www.rcgroups.com/forums/showthread.php?t=980759&page=3#post11815425]this[/link]
Any ideas / photos?
Old 05-11-2012, 07:38 AM
  #2488
Never
Very nice three-color scheme.
What colors did you use?
My Corsair has an OS FS 110, and retractable landing Century Jets
Marco
Old 05-11-2012, 07:58 AM
  #2489
w1nd6urfa
w1nd6urfa's Avatar
Hi Marco,
I used House of Kolor which are for motorbike tanks and helmets. I made the camo colors from the elementary ones, mixing by eye.
I've also worked with Model Masters and Gunze, all good.
Nick
Old 05-13-2012, 04:49 AM
  #2490
tevans55
I used Aces of Iron pilot in my H9 Corsair.
ID:	1762171   Click image for larger version
Old 05-13-2012, 08:47 AM
  #2491
w1nd6urfa
w1nd6urfa's Avatar
Great looking pilot, pity they don't have full body figures
Old 05-13-2012, 08:56 AM
  #2492
w1nd6urfa
w1nd6urfa's Avatar
Successful maiden, looks great and very easy flier. Love this plane!
Thanks you Dangaras, LDM, v6goose, pogoed, (and many others that I forget!) for posting here and being an inspiration turning this ARF into a scale project.
Nick
ID:	1762241   Click image for larger version
Old 05-20-2012, 11:51 PM
  #2493
rino
My Feedback: (121)
Would anyone have a pic or description of how to glass the inside of the firewall. I'm building and H9 Corsair now and want to do the proper mods first.
Steve
Old 05-21-2012, 12:51 AM
  #2494
w1nd6urfa
w1nd6urfa's Avatar
rino
The area inside the firewall - tank is quite large but with a small opening due to the tank mount.
Therefore the technique is:
- Cut about 20 small pieces (1" square) of 1/2 oz cloth
- Mix finishing epoxy and use a brush to spread it on the firewall and all the wood in the tank area. You might want to bend the epoxy brush to get to the hard to reach areas like the bottom of the tank area
- Place the cloth on the firewall-fuse joint and anywhere else you can using long tweezers or a hemostat
- Use the brush again to wet the cloth with more epoxy
Photos after glassing
ID:	1764574   Click image for larger version
Old 05-21-2012, 06:50 PM
  #2495
rino
My Feedback: (121)
Guys, I have another question. I have a DLE 20 that I was planning for the Corsair. I know the capabilities of this engine and it's quite powerful for its weight. I also like to fly fast. 120 mph would suit me fine.
So, is the H9 Corsair or any of the H9 warbirds for that matter worth the work if you like to fly fast. It looks risky from what I've read. I have no problems reinforcing the firewall, but the wing is not so simple.
And please, no lectures about putting a a 60 sized motor or Saito 100 on this bird. I did not buy it to drive it slow.
Other options might be to sell and go Top Flight or Black Horse Models. Americanpioneerhobbies has a well-built BH Spit that can handle the speed.
Old 05-21-2012, 08:18 PM
  #2496
w1nd6urfa
w1nd6urfa's Avatar
I would agree the Corsair is risky for that type of flying and the heavier it gets the more trouble you'll get with rotating retracts.
A Spit, P-51, Me-109, FW-190, Ki-84 should be safer, faster and more fun
Meanwhile here's some cockpit shots:
ID:	1764972   Click image for larger version
ID:	1764973   Click image for larger version
Old 05-22-2012, 05:41 PM
  #2497
drube
drube's Avatar
I picked up a used H9 corsair thanks to the wifey, she bought it for me. I've read this whole thread and learned so much about this plane thanks to you guys!
Saito 100, 14x7x3 MA Prop, JR digital servos, JR retract servo,Stock Retracts, CG at 4.5"and reinforced the main spar around the retract plate. Looking to fly it tomorrow for the first time. Can any one compare this to the Hellcat or P-51 Marie's flying Characteristics? I love those planes!
I plan to glass and paint at some point, do you think the Saito 100 will still be ok power wiseafter Glass and paint?
Old 05-22-2012, 07:24 PM
  #2498
rino
My Feedback: (121)
Do you have any pics on how you reinforced the main spar? Did you cut into it to do it?
Old 05-22-2012, 08:03 PM
  #2499
w1nd6urfa
w1nd6urfa's Avatar
drube,
Mine is painted and clearcoated, with Lado retracts, robostruts and Robart scale wheels (all heavier than stock), dry weight about 8,5 lbs. The Saito 100 turning 14x7x3 @ 9,200 RPM gives plenty of power and she's not fully broken in yet
rino,
I reinforced the retract mount - bottom spar using a U-shaped steel rod (see pics). I use this mod on planes with rotating retracts (eg P-40s) ever since the wing folded on my H9 Hellcat at this very spot.
I also glass the wheel bay area and wet all accessible ribs, spars, leading edge etc with thin CA
ID:	1765162   Click image for larger version
ID:	1765163   Click image for larger version
Old 05-23-2012, 03:39 AM
  #2500
dawhale
My Feedback: (20)
I have an example of a carbon reinforcement if someone can tell me how to post a picture from my desktop.
