H9 1/4 Cap Elevator/Horn Question >
Old 04-23-2002 | 11:17 PM
Default H9 1/4 Cap Elevator/Horn Question
Hey Guys,
Was wondering if anyone has made any modifications on the horn mount points of the elevators.The instructons say to mount the supplied horns to the inner leading edge corner which is made of balsa. This gives you about 1 mm of wood on either side of the horn bolts. Even though the horn has a backer plate on the top side of the elevator, it doesn't seem like there is enough "beef" for the horn bolts on a "3D machine"? What do you guys think ?? Thanks!!
Old 04-23-2002 | 11:20 PM
My Feedback: (40)
I have built 2 of these as the instructions say and I have not had any problems with them.
Jeff
By the way, I am tugging mine around with a BME 50 if that gives you any idea of the stress those horns are under.
Old 04-23-2002 | 11:23 PM
The area for the elevator horns are way to small, I ended up removing a piece of covering to reveal that area, and I beefed it up with some ply giving it more area to sit on. Daz...
Old 04-24-2002 | 12:42 AM
My Feedback: (13)
That's exactly what I'm planning to do, Daz. I already opened up the bottom rear to install a plate for the Klett tail wheel; what's two more lousy elevators?<G>
Steve
Old 04-24-2002 | 01:02 AM
Good Steve, its unbelievable that they made that area so small. It would have been so easy to do before they covered it. Daz...
Old 04-24-2002 | 01:31 AM
Just opened up my first elevator and found that at least they capped the attaching balsa with a 3/16" piece of what appears to be pine. I added a piece of pine about an inch long. That should do it! Thanks for the suggestion Daz!
Old 04-24-2002 | 01:47 AM
No problem bralex, better SAFE than SORRY!!! Daz...
Old 04-24-2002 | 02:25 AM
My Feedback: (25)
Default Done two of them...
Did one stock and added a triangle to the other. Have not had a problem with either.
