World Models 300 80"
PA
Has anyone out there with this airplane had problems with the wing bolts vibrating loose?
Especially the guys with gas engines in this plane.
No,
I use the double nuts that came with the kit and have not had a problem. I did epoxy the tail feathers on as per instructions when using larger engines.
I love mine, it flys smooth and will perform almost any manuever.
Good luck
Good luck
NJ
I used there supplied nuts as safetys and installed metric wing nuts first. Much easier to tighten only had two flights before I sold the plane though. I use the same setup on my 35% planes without a problem.
Kevin
Kevin
