Phoenix Scanner >
Phoenix Scanner
Phoenix Scanner
Old 09-20-2014 | 12:19 PM
Question Phoenix Scanner
Hey guys ,
I ordered a Phoenix Scanner a few days back from my LHS and it came today . I was reading the manual and it tells that there is a dihedral brace Present in the kit , i went around my kit and found none however there is a round metal wing joiner tube present . Wanted to know has the manual not been updated ? Or the dihedral brace should have been there ? If its not there how should i get around this issue ? Please help as this will be my first low winger
Old 09-21-2014 | 03:56 AM
TomCrump's Avatar
There should be contact info from the importer, in your assembly manual.
Use it and ask them..
Old 09-21-2014 | 04:32 AM
The plane is set up so that the wing may be broken down into 2 pieces for easy transportation and storage. To use, just slide each half onto the wing tube and fasten to the fuse as you would normally fasten a 1 piece wing.
As far as the directions, maybe they haven't been updated. Not too big a deal. This is a pretty straight forward assembly. If for whatever reason you'd prefer a one piece wing, use the wing tube in place of the dihedral brace. Slide everything together, line it up, and glue away....
Old 09-21-2014 | 04:52 AM
I agree to thr easy transportation part but i would like a one piece wing , i still want to clear one thing if i only use a metal tube and epoxy it in place without the brace will it affect the overall strength of the wing
Old 09-21-2014 | 05:28 AM
With the wing tube in place, the wing will be AT LEAST as strong as if a dihedral brace had been used.
Old 09-21-2014 | 06:02 AM
Thanks that helped a lot can start working on it now , will be converting it to an electric using .46 rimfire with turnigy 60amp esc
