Retracts
What type do you want? Air, mechanical, or electric? Simplest to use and cheapest are mechanical. for a 7lb plane you can order them from any of the big guys like Tower and Horizon. You will also find air and electric there to. You will also need a special retract servo for mech retracts about $25 retracts will run you about the $15 for a set of mains. Tri gear gets a little more complicated.
My Feedback: (90)
It would appear there is more than 1 version of .60 Tucano ARF from Phoenix. Here are a few build threads:
http://www.rcgroups.com/forums/showthread.php?t=1708708
http://www.rcgroups.com/forums/showthread.php?t=2292015
http://www.rcgroups.com/forums/showthread.php?t=2055611
http://www.rcgroups.com/forums/showthread.php?t=1876082
http://www.flyinggiants.com/forums/s...ad.php?t=93430
