Phoenix Models Yak 54 >
Old 05-30-2016 | 10:54 PM
Sukhoi_Madness's Avatar
Default Phoenix Models Yak 54
Hi guys,
I have a Phoenix Models Yak 54 .60 - .90 size.
The engine in the assembly manual is an OS .91 but I'd like to put in a petrol engine instead.
Something like a DLE-20RA.
This engine only appears to be about 100grms heavier.
Has anyone got any experience / advice on a petrol engine for this airframe.
Old 06-02-2016 | 06:52 AM
I assume your looking to 3D the plane? I have a Phoenix model edge 540 being delivered today. I have a dle20ra resdy to put in it, as many other members did. But the edge is a .91-1.20 size plane. I think the dle20ra would work and it would be a power house, but you may be looking at definetly modifying/reinforcing the engine box/firewall. Not sure how the cowl will fit either... I think you could get it to balance. Move the fuel tank back to under the wing tube. And have your battery/receivee/ throttle servo behind the cg point.
Just my thoughts..
good luck!
Old 06-03-2016 | 09:34 AM
Just my thoughts..
good luck!
Thanks for the feedback.
Not for 3D actually just scale aero so I'm not worried if its a little heavy as long as it balances nicely.
