Wing joiner >
Wing joiner
Wing joiner
Old 04-13-2019 | 07:15 AM
Default Wing joiner
recently given a seagull extra 260 with a 1.80 4 stroke magnum. The plane needed a few items which was no problem but was missing a wing joiner tube. I had measured and came up with a 1.27 od. I have gone on seagull to find a dimension but had no luck.
Does anyone have a idea of the correct sizing.
Regards,
Greenberet
Old 04-13-2019 | 10:21 AM
BarracudaHockey's Avatar
moved to correct forum
Old 04-13-2019 | 07:02 PM
Regards,
Greenberet
if this helps>>
1.27 , that is 32,2580 mm
https://www.towerhobbies.com/help/convcalcs.html
Jim
Old 04-14-2019 | 05:40 AM
flyboy2610's Avatar
Originally Posted by the Wasp
if this helps>>
Jim
Do you mean 32.258 and not 32,258?
Old 04-18-2019 | 04:08 PM
Just get a wood dowel that close and build it up with masking tape until you get the fit you want.
